Stupidest damn question--but has a good chance in becoming real.
Old Jun 24, 2002 | 09:38 AM
ludeNstein's Avatar
Default Stupidest damn question--but has a good chance in becoming real.
--HOW fast would a STOCK ~95 Prelude Vtec GO if is were REAR WHEEL DRIVE, and weighed just UNDER 1900 POUNDS with 8.5 inch tires???
--The reason i ask this is because I have a good chance into making this reality (otherwise, i wouldnt ask - just dream.) -and of course im gonna build the motor, but after just buying it leaves a pretty big hole in your pocket - if you know what i mean... --but just give me a GOOD GUESS...
--And if i make it, I guarantee I will be in magazines, and youll know i wasnt ****** around.
Old Jun 24, 2002 | 09:52 AM
JG Luder's Avatar
Default Re: Stupidest damn question--but has a good chance in becoming real. (ludeNstein)
#1. you have to do it now that you've talked the **** about it.
#2. Yes, I do know it can be done. I even know how, but I'm not sharing my tips.
#3. with slicks you should pull 1.70's 60ft times. So, not a whole whole lot faster on a stock motor. Build it, and run 1.40's in the 60's and you should knock off at least .2 on the end time.
Old Jun 24, 2002 | 09:58 AM
tec-9-7's Avatar
Default Re: Stupidest damn question--but has a good chance in becoming real. (Todd 94)
Hell, if they could do it w/ a Tib, why not a 2-engine, AWD, 4WS 95 Prelude VTEC????
Huh???
WHY NOT ONE OF THOSE!?!?!?!?!?!?!?!?!
Paul
Old Jun 24, 2002 | 11:55 AM
Daemione's Avatar
. . . . . a STOCK ~95 Prelude Vtec GO if is were REAR WHEEL DRIVE, and weighed just UNDER 1900 POUNDS with 8.5 inch tires???
Isn't that a little bit of an oxymoron? That's hardly a stock Prelude. If you intend on making an H22 powered go-kart . . . . given the above specs I'd guesstimate a low 12 second quarter mile. And why such narrow tires? That's only a 215mm width.
Old Jun 24, 2002 | 01:29 PM
laughinxxx's Avatar
New User
Default Re: Stupidest damn question--but has a good chance in becoming real. (Daemione)
Yep that's high 12s to mid 13s.
Old Jun 24, 2002 | 03:19 PM
PrecisionH23a's Avatar
Default Re: Stupidest damn question--but has a good chance in becoming real. (laughin2.2)
keep us updated on the project. if you back out, we will have to flame you.
[Modified by GudeH23a, 7:20 PM 6/24/2002]
Old Jun 24, 2002 | 03:29 PM
JG Luder's Avatar
not on a stock motor. it won't be any faster. if anything, because of the extra work you'd have to do and the weight it added, it might be the same speed.
only when you highly mod it will you find that RWD has its advantages.
Old Jun 24, 2002 | 04:22 PM
Finest's Avatar
Mahdavi Motorsports threw an NSX engine in a CRX and ran mid 11's on drag radials. Keep in mind this is a STOCK NSX motor.
With the proper mods, you can pull some pretty wicked numbers.
But be prepared to drop a few buckets of cash in the project.
Old Jun 25, 2002 | 03:31 AM
Default Re: Stupidest damn question--but has a good chance in becoming real. (Prelude_RCR)
yea but that ****** is GUTTED to hell and back.... plus the crx is WAY lighter then the prelude to begin with.
Old Jun 25, 2002 | 04:32 AM
ludeNstein's Avatar
-THANKS FOR YOUR GUESSTIMATES GUYS!!! Anything in the 13 for an UNBUILT motor sounds good to me.
--Wider tires means i need a wider pocket! -Although wider is better -but 215mm is only 7.5 inchs, 8.5 is 225 or 235mm.
---For this project to go through, i just need for my loan to go through, and for my insurance to be a little bit lower. -and ill be sending you guys post cards - lol - jk..
----im starting to like this forum more now...
Old Jun 25, 2002 | 06:15 AM
Daemione's Avatar
1 inch = 25.4 mm
Old Jun 25, 2002 | 08:54 AM
Finest's Avatar
Default Re: Stupidest damn question--but has a good chance in becoming real. (GudeH23a)
In his first post, he said the chassis will be around 1900lbs. 200hp+1900lbs = mid 12's easily, esp with RWD.
Old Jun 25, 2002 | 09:02 AM
Uhoh... here come the excuses already... hehe just kidding. Keep us all updated on the project.
95eggsr66
May 25, 2012 05:09 AM
H22JEFFREY
Sep 22, 2004 01:58 PM
accord03coupe
May 21, 2004 08:24 PM
mugen_rsx
Jun 12, 2001 07:34 AM
