55watt DIGITAL High-Output HID kits, $160 shipped!, lifetime warranty!
Old Nov 13, 2007 | 07:44 PM
retrosolutions's Avatar
Default 55watt DIGITAL High-Output HID kits, $151 shipped, lifetime warranty!
ONLY $151 SHIPPED! on lowbeam kits!
WE GUARANTEE THIS TO BE THE HIGHEST QUALITY HID KIT ON THE MARKET!
No Gimmicks, No gags, No BS!
-These are the brightest HID kits on the market
-These tightest beam pattern of any kit on the market
-A LIFETIME WARRANTY backs the highest quality possible
CLICK HERE TO ORDER! USE "HONDATECH" Discount Code
These exclusive kits feature 55 watt high-output DIGITAL ballasts. At 55 watts of true power, these ballasts will offer more light (30 - 40%) than any other HID kit on the market! Ballasts are 100% digitally controlled, which allows extremely high efficiency, low starting current, and low operation current. This all means super reliability, better longevity, and 100% flawless plug and play operation on all cars, trucks, and other vehicles. Ballasts are waterproof, dustproof, and shakeproof and feature hot-retrike technology to protect already warm bulbs from excessive damage when restarting.
Bulbs featured in these kits are the best among all kit manufacturers, with the least variance available on the market, all within +/- 100 lm (brightness) and +/- 200K CCT (color). Average lifespan rating is 3500 hrs, compare to others of significantly less! Focal points on these bulbs are the best we have ever seen in any other kit, resulting in some of tightest and most uniform beam patterns to come from converted lamps. The resulting beam pattern is UNMATCHED by any other kit we have EVER tested!
All items are brand new, packaged in sturdy aluminum cases for ultra-safe shipping!
CE and UL safety listed, ISO registered manufacturing, E4, E11 TUV mark. All genuine parts are individually serial numbered.
Only the best German proprietary processors, and high quality components from NXP semiconductor, Texus Instruments, International Rectifier, Fairchild Semiconductor are used to obtain the lowest failure rate of any after market ballast in the market to date.
Each kit inlcudes:
- 2x DIGITAL waterproof 55 watt ballasts (Best on the market, <0.05% failure)
- 2x 55 watt HID bulbs (Best on market, <0.16% failure)
- 2x plug and play pigtails for your application
(Bixenon High/Low beam kits include fully integrated plug and play harness)
- mounting hardware
- attractive metal case
- Lifetime warranty on all parts!
All bulbs types available: H1, H3, H3C, H4/9003, H4/9003 Bixenon*, H7, H8, H9, H10, H11, H13/9008 Bixenon*, 9004 Bixenon*, 9005, 9006, 9007 Bixenon*, D2S
* +$10 for Bixenon options
Colors available: 2000k*, 3000k*, 4300k, 5000k, 6000k, 8000k, 10,000K*
*Less common bulb types and colors are available by request, some applications have these in stock, some are special order.
Group buys are welcome and encouraged to receive even better pricing!
Payment:
We accept payments via Paypal, Google Checkout, Money Order, Cashier's check, or even a cleared personal check.
Warranty:
Lifetime warranty, period. No hassle, just send it to us and get a replacement ASAP.
IM us on MSN at retrosolutions@***.net
Modified by retrosolutions at 12:11 PM 11/3/2008
Old Nov 14, 2007 | 01:48 PM
don't be fooled by cheap unreliable kits, you only need to buy one HID kit to out last your car!
Old Nov 15, 2007 | 03:39 PM
honda_racing101's Avatar
any more pics installed?
Old Nov 15, 2007 | 07:12 PM
Default Re: (honda_racing101)
Old Nov 15, 2007 | 07:18 PM
Old Nov 15, 2007 | 07:23 PM
Old Nov 16, 2007 | 05:50 PM
Default Re: (rsx-ct)
BUMP!
Things this kit offers that NO OTHER kit can offer you:
1) Brightest output on the market
2) Lifetime Warranty
3) Most precise beam pattern of any kit bulbs
Old Dec 1, 2007 | 05:49 PM
MiX's Avatar
MiX
any deals on purchasing multiple sets. DO you or do you not have 3k and if u do is the light yellow or the hid bulb have a yellow film on it?
Old Dec 2, 2007 | 08:17 AM
Default Re: (MiX)
Yes, we will do deals on multiple sets shipped to the same address. We do have 3000k and 2000k for some low beam only applications, it depends on what you need for your vehicle? In some cases, depending on what you need and color you choose it can be made for you if we do not stock it normally.
sales@retro-solutions.com
Old Dec 8, 2007 | 01:55 PM
Rishiras's Avatar
Default Re: 55watt DIGITAL High-Output HID kits, $170, lifetime warranty! (rsx-ct)
How does the H4 come? Low beam HId and high beam normal halogen? for inspection i need it so to pass.
let me know,
R
Old Dec 10, 2007 | 04:30 PM
actek23's Avatar
Default Re: 55watt DIGITAL High-Output HID kits, $170, lifetime warranty! (Rishiras)
how long have you been in the business??
Lifetime warranty is good esp for HID kits...
i might pick up a set for my gf's car.
Old Dec 10, 2007 | 04:55 PM
We have two choices for H4, the standard is a H/L bixenon kit that has electro-magnetic xenon bulbs to perform both functions. The other option is a single beam version, which I would not recommend for you in your case. The best part is, we do not charge extra for the more sophisticated H/L bixenon kits liek all the other vendors do, same low price!
Old Dec 10, 2007 | 05:00 PM
Default Re: 55watt DIGITAL High-Output HID kits, $170, lifetime warranty! (actek23)
We have been around since early 2004. We previously only provided and worked with OEM equipment because until now there was no real reliable aftermarket parts available out there. We changed that by initiating our own manufacturing, we do not simply rely on the mercy of ultra-cheap manufacturing companies and take whatever we can get like all the other vendors do, we turned the tables to offer a much higher quality.
Old Dec 10, 2007 | 05:14 PM
actek23's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsx-ct &raquo;</TD></TR><TR><TD CLASS="quote">We have been around since early 2004. We previously only provided and worked with OEM equipment because until now there was no real reliable aftermarket parts available out there. We changed that by initiating our own manufacturing, we do not simply rely on the mercy of ultra-cheap manufacturing companies and take whatever we can get like all the other vendors do, we turned the tables to offer a much higher quality. </TD></TR></TABLE>
wow... 3 years and still going strong... imma definitely look into your company when i buy my gf's HID kit. thanks!
seriously cant go wrong with lifetime warranty!
Old Dec 10, 2007 | 09:27 PM
bpr0422's Avatar
sweet box!
does it really come in that box???
is that box metal? or just plastic/cardboard made to look like metal?
Old Dec 11, 2007 | 05:57 AM
orion840's Avatar
Default Re: 55watt DIGITAL High-Output HID kits, $170, lifetime warranty! (bpr0422)
kits look good mang
Old Dec 11, 2007 | 11:59 AM
Yes, they really come in that box!
They are a thin gauge aluminum with a composite laminate layer on the outside for rigidity, and padded inside. The cases do an excellent job to protect the contents in shipment.
Old Dec 12, 2007 | 08:16 PM
iLood's Avatar
Lifetime warranty covers everything? When the ballast/bulb eventually wears out they're replaced free? If so, I'll order 8k H7's soon, that is if you don't carry 10k.
Modified by iLood at 9:28 PM 12/12/2007
Old Dec 13, 2007 | 01:50 PM
Default Re: 55watt DIGITAL High-Output HID kits, $170, lifetime warranty! (iLood)
Yes, lifetime warranty cover everything except intentional or accidental abuse. Basically you are covered unless they are damaged in an accident.
We have H7 in 8000k and 10,000K
Old Dec 13, 2007 | 01:56 PM
iLood's Avatar
Good to hear. I'll order soon. Are your 8k and 10k basically the same as other are, color wise? 8k being dark blue and 10k being dark blue with a hint of purple.
Old Dec 13, 2007 | 02:05 PM
Old Dec 13, 2007 | 05:11 PM
ef8status's Avatar
seems legit
Old Dec 13, 2007 | 07:26 PM
Default Re: 55watt DIGITAL High-Output HID kits, $170, lifetime warranty! (ef8status)
Yes, we are 100% legitimate, please come by and check out the website, or ask us for some feedback, we would be happy to provide it. On a side note, I don't think you will come across many illegit vendors on these forums as long as you stick the vendor classifieds, we all have to pay to be here.
Old Dec 14, 2007 | 07:32 PM
iLood's Avatar
Just ordered 8000k H7's.
Free bump.
Old Dec 14, 2007 | 07:39 PM
cktenders's Avatar
I just ordered a 6k bi xenon kit today as well. Can't wait!
