Tons and Tons of parts for sale-NA, FI, OEM just look inside everything is OBO
Old Nov 13, 2007 | 06:31 PM
per4mance's Avatar
Default Tons and Tons of parts for sale-NA, FI, OEM just look inside everything is OBO
Selling for a friend.
Contact info: Michael – 665-5557 or 489-9293
everything is OBO + shipping
Or you can pm me on here and i can relay the message
B16 cable tranny $550
B20 Shortblock (Includes- RS Machine 84.5 Pistons, Shotpeened & reconditioned pr4 rods, 9mm ARP rods bolts, ACL Main Bearings, Factory Honda rod bearings {green}, Polished Crank, JG Sleeved Block, ITR Oil Pump, Honda B20 Head Gasket, ARP Head Studs)- $1200 dissassembled or $1400 assembled
B20B bare block with main caps - $225 cylinders are perfect
B20B Crankshaft - $100-$125 great shape
JE 84mm Turbo Pistons used for 10000 miles - $200
Manley or Crower dont know which ones reall but regardless in great shape and bigger then eagles used for 10000 miles (B18A/B or B20) - $300
Wilwood Dynalite Big Brake Kit 11inch Front used 5000 miles (Fits Civic 1990-2003 [most 15” wheels] Full Kit; includes stainless steel brake lines, assembled with ARP hardware.) comes with two one off 1/8" wheels spacers to clear oem honda/acura wheels - $450
EF Civic Rear Disc Brakes (full conversion w/ emergency brake) - $200
Function7 Rear Lower Control Arms Polished used 2000 miles (Fits EF & EG, individually serial numbered) - $165
99-00 Civic Si Wheels (with camber worn BFgoodrich traction T/A) - $275
Tokiko Blue struts with lowering Springs used 10000 miles (for EF HB) - $180-$220
OmniPower Rear Upper Control Arms used 5000 miles (camber adjustable) - $60
OmniPower TPS (NEW) - $50
Koyo Full Radiator (EF, includes electric slim fan) - $250
AEM Cold Air Intake (EF) - $75
Skunk2 Intake Manifold & BBK 70mm Throttle Body combo (port matched intake manifold opening) - $350
AEM underdrive pulleys and Adjustable Cam Gear (D16, Red pulleys, Blue Gear, includes belts) - $125
92-93 GSR Black Cloth Seats (no tears) - $200
Hydraulic Transmission (from D16Z6) - $100
Hasport Custom AC Bracket (for B-series swaps into EF Civic/CRX) - $150
650cc Injectors & Warlbro 255 Fuel Pump - $300
EF Civic Rear Hatch 2x - $50 each (one is red and one is grey)
EF Civic Doors 2x (Belts in doors) - $50 each or $75 per pair ( one pair is red and one pair is grey both have good windows)
CRX Door Panels - $25 each
EF F&R Strut tower bars (need refinishing) - $25
EF Civic Passenger Seat - $50
EF Factory Intake - $25
EF Civic F&R Bumper Filler - $25 each
D16Z6 Head (complete) - $70
D-Series Starter - $40
EF Front Rotors (Drilled & Slotted) - $30
EF Civic Front Hubs, Rotors, & Calipers - $100
EF Civic Rear Windows 2 sets (regular & tinted) - $100 per pair
Again everything is obo and I can get picks on items which are asked about
Modified by per4mance at 6:12 PM 11/19/2007
Old Nov 14, 2007 | 11:10 AM
per4mance's Avatar
Default Re: Tons and Tons of parts for sale-NA, FI, OEM just look inside everything is OBO (per4mance)
bump
Old Nov 15, 2007 | 10:09 AM
per4mance's Avatar
bump
Old Nov 19, 2007 | 05:10 PM
per4mance's Avatar
bump
Old Nov 21, 2007 | 06:23 AM
Disco Monkey's Avatar
you have a pm.
Old Nov 21, 2007 | 07:03 AM
shadow102's Avatar
shipping on the tokico's and strut bars to 30102
Old Nov 23, 2007 | 05:21 PM
per4mance's Avatar
Default Re: (shadow102)
bump
Old Nov 30, 2007 | 06:12 AM
per4mance's Avatar
bump
rwdkid
Jun 17, 2013 09:48 AM
92integraVTECgsr
Southeast (Sales)
Apr 14, 2010 10:01 PM
Golden Eagle
May 2, 2008 08:26 AM
lazydude-t
Apr 19, 2006 06:59 PM
lazydude-t
Texas -OK -LA (Sales)
Apr 13, 2006 01:10 PM
