da,db,dc,eg,ef,hf,d16,d15,b18,b20,civic,integra,pa rts
blk acura airbag 96
b1 throttle body
b1 fuel rail
b1 intake manifold
b1 engine harness clipping out
b1 stock exhaust
b1 fuel rail
b1 alternator
b1 crank pulley
b1 AC compressor
b1 stock dizzy w/ msd clear cap
b1 thermostat
b1 valve cover
96 AT trans
96 AT torque convertor
96 at bousch newer starer
d series intake manifold
d16z6 skunk 2 adj cam sproket
d16z6 power steering pump w/ aem true power pulley
D & B series fly wheels
eg coupe drivers door wiring
eg coupe cruise controle
eg coupe stock wing
eg hb stock front springs
90-93 integra
used brake master cylinder
rack in pinion
rear brake assembly disc conversion civic crx
4 door tail lights
fuel door
dash
steering wheel
e brake
4 door windows and door panels
front bumper reinforcement
4 door back seats
4 door seat belts
trunk and fuel door release
rearview and side mirriors
front cross member
passenger rerar control arm
5 pt simpson harness
17 inch polished nakayama rims new tires
radiator overflow and fan
cruise control
ls trans 5 speed
black projector head lights
cluster
stock headlights
motor mounts
harmonic balencer
after market header
ls head
half shaft
obd0 ecu
shift linkage
b series throttle body
16083334977 ask for rico
b1 throttle body
b1 fuel rail
b1 intake manifold
b1 stock exhaust
b1 fuel rail
b1 alternator
b1 crank pulley
b1 AC compressor
b1 thermostat
b1 valve cover
96 AT trans
eg coupe stock wing
90-93 integra
rack in pinion
4 door tail lights
fuel door
dash
steering wheel
e brake
4 door back seats
4 door seat belts
front cross member
cruise control
ls trans 5 speed
cluster
stock headlights
motor mounts
harmonic balencer
after market header
ls head
half shaft
obd0 ecu
shift linkage
how much you askn for the b18 cable trany??? whats the model and condition of it? if its at the right price ill take it off your hands.
suno
Mar 29, 2008 12:18 PM
