Pictures and a Video of my y7 to y8 conversion...need feedback!
Here are some pics of my y8 manifold on my y7...How do I eliminate the setup that my y7 intake had in this first pic...in other words...what vacuum goes where? Please help me get these vacuum's in the right place. thanks!
What vacuum goes on this empty spot on the throttle body?
And a short video of my car's messed up idle...When I relocate the wire on the ecu and remove the orange one will this get better?
I can’t believe how many botched Y8 manifold swaps I see on this site. Holy **** you have a vacuum line directly connected to the valve cover PCV breather, and I wouldn’t be suppressed if you have a coolant line running directly into the purge solenoid. You get a double
from me.
Get yourself a helms manual ASAP, you need help.
from me. Get yourself a helms manual ASAP, you need help.
Try this out for now for info:
http://www.ef-honda.com/ben/Badidle.php
Ill find you a y8 I/mani crossection hopefully, with all the vaccum tubes posted.
i had little problems with my y8 IM swap but damn son, you need to find a bunch of write up's on d-series.org, turbo d16, here, hell check google(y8 intake manifold swap on a d16) and read alot.
the TB has a coolent line going to it i know for a fact. and the hose at the top or you manfold that you have going to the valve cover is not right, cant remember how it goes or if that nipple on the top of the IM is for coolent, but the one on the valve cover is deff for breather(hook it up to your intake or put a little mini filter on it)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22egAZ »</TD></TR><TR><TD CLASS="quote">i plan on swapping the Y8 manifold soon and head...... just want 2 know if u get a lil more HP on by just swapping the manifold
at most probably 2whp to the wheels, what you want is a y8 tranny that will benfit probably like 5x more than the mini me swap litteraly.
</TD></TR></TABLE>at most probably 2whp to the wheels, what you want is a y8 tranny that will benfit probably like 5x more than the mini me swap litteraly.
sweet jesus that's a mess. the ports on the bottom of the TB are for coolant, but just go ahead do a TB coolant bypass to make life easier. also what year car did the y8 manifold come off of? if it was a 99-00 the mani has air injection holes on the mani flange that need to be sealed up. go check out d-series.org, they got tons of info on it and really helped me when i did it...
i have never even owned a sohc honda engine...only h22's and those old junk b20's(prelude)..i know my h22 is awesome especially in my hatch....
Why do people put a y8 mainifold on a y7? you still have no vtec,correct? a y7 is a non vtec motor i assume. I know this is a silly ? but whats the big deal? i see so many threads referring to this same swap. I am just not very educated on the sohc/ sohc vtec honda engines.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleepyH22 »</TD></TR><TR><TD CLASS="quote">i have never even owned a sohc honda engine...only h22's and those old junk b20's(prelude)..i know my h22 is awesome especially in my hatch....
Why do people put a y8 mainifold on a y7? you still have no vtec,correct? a y7 is a non vtec motor i assume. I know this is a silly ? but whats the big deal? i see so many threads referring to this same swap. I am just not very educated on the sohc/ sohc vtec honda engines.</TD></TR></TABLE>
just for more powa!
the y8 manifold is the ITR manifold of SOHC.
so you ll get a lil boost in hp a cheap effective way. Good for FI later too.
just for more powa!
on the driver side lower back of the IM you might find a little open nipple, you can plug that up .its used for cruse control. and DX dont have that of course =P
i did the 3 to 2 wire conversion...everything is y8 but I havent disconnected the orange cable from the ecu nor have I switched the black/blue cable.
what's wrong about the valve cover hardline connecting to the top port of the manifold? the red line I believe is connecting to the front lower port and connects to the rear of the manifold. where should it be connected?
Dude, get yourself a helms manual ASAP! Theres so many hoses that are hooked up wrong.
