RSX rotors and calipers fit on a type r?
Old Nov 13, 2007 | 02:22 PM
187Chor's Avatar
Default RSX rotors and calipers fit on a type r?
i wanted a slightly bigger brake combo without having to switch to an aftermarket big brake kit..
can i swap my rotors calipers n pads from the rsx onto my type r
i plan to swap to the 16 inch rsx wheels as well
Old Nov 13, 2007 | 03:11 PM
Henryx33's Avatar
Default Re: RSX rotors and calipers fit on a type r? (187Chor)
I'm getting rid of my RSX wheels soon. If you want to see what they look like just pm me
Old Nov 14, 2007 | 12:08 PM
Circuit Star-29's Avatar
Default Re: RSX rotors and calipers fit on a type r? (Henryx33)
There was a thread about this not too long ago. basically, you can use the rotors if you machine about 1mm out of the hub of the rotor. Caliper bolts right up, from what I remember...
Old Nov 14, 2007 | 12:36 PM
jomama's Avatar
why not just go with the legend 2-piston calipers?
Old Nov 14, 2007 | 04:44 PM
MooFX's Avatar
I think the RSX uses same size rotors as the S2K. I've tried fitting the S2K rotors on my R but you will either need to shave down the wheel hub or the inner of the rotors. I ended up using the Spoon 300mm rotors to work with my Spoon Monoblock (RSX/S2000 sized) calipers, which happens to be for sale right now.
https://honda-tech.com/zerothread?id=2151661
Old Nov 14, 2007 | 09:07 PM
ITR.#1446's Avatar
Default Re: (MooFX)
saw this on k20a.org today might help
http://www.k20a.org/forum/show...+hubs
xiongtoua1990
Apr 12, 2009 11:02 PM
kevEK9
Apr 4, 2003 08:38 PM
trackie
Dec 17, 2001 07:08 AM
