accord tranny
[B i read that the h23 tranny had longer and stronger gears. Seen lot of people chose the h23 tranny over both the f22 and h22 on lude. Anyone know if the h23 tranny will work on a f22b1 motor? will it bolt right up? any other adjustments i have to do? please leave feedback.[/B]
yes. it will all fit. search.
the Hxx series have shorter gears than Fxx series trannies. You will gain aceleration but loose top end. you will rev higher on the highway
It will bolt up to the motor but if your putting it in an Accord you need to use the Accord tranny mount and drill and tap threads into the other 2 holes on the tranny.
tossnupweight
Jul 9, 2003 06:34 AM
