Big Problem, Need help
Old Nov 13, 2007 | 01:59 PM
youdontneed2cams's Avatar
Default Car cut off for no reason, Need help
I was driving along in my ek d16y8 when all of a sudden i lose power and my battery light flashes really quickly, i pull over and open to hood to check the basics and i see that one of my plug wires had come off the dizzy, my question is could i have fouled the plug that quickly to where it wouldnt start when i put it back, i need help fast becasue im stuck in bf egypt and i dont have many other options than fix it, i did find a wi-fi network though
Old Nov 13, 2007 | 02:02 PM
bump, anyone???? please im stranded
Old Nov 13, 2007 | 02:05 PM
anyone?
Old Nov 13, 2007 | 02:08 PM
sc95delsol's Avatar
Default Re: (youdontneed2cams)
just a shot in the dart but it is probally has nothing to do with your spark plugs and everything to do with ur alternator going bad see if u can get a jump start and then take off one of ur battery terminals it starts, one other ? is it a weak turn over? if it dies if it starts when u take off battery terminal its ur alterantor
Old Nov 13, 2007 | 02:09 PM
thats what i thought at first but i checked the voltage output w/ a volt meter and it was giving a steady 14 volts and the car still cranks, any other ideas?
Old Nov 13, 2007 | 02:11 PM
sc95delsol's Avatar
do u have any tools on u to take ur cap off and see if anything is fouled
Old Nov 13, 2007 | 02:12 PM
i have someone bringing me tools so im going to check my plugs and my distributor cap, can i mess up the ignition timing by removing it?
Old Nov 13, 2007 | 02:13 PM
sc95delsol's Avatar
not by removing the cap or spark plugs is ur dizzy loose at all????
Old Nov 13, 2007 | 02:15 PM
ill have to check, im just praying its the plug
Old Nov 13, 2007 | 02:21 PM
sc95delsol's Avatar
post back and let us know how it goes
Old Nov 13, 2007 | 07:53 PM
i bought and obd scanner and after i researched the codes and i got a code for my eld, i looked around but i cant find where to get one of these things anywhere, any thoughts?
Old Nov 13, 2007 | 08:24 PM
4thgenhtch's Avatar
an eld? Its in the bay fuse box, hit up a junkyard
Old Nov 14, 2007 | 06:28 AM
so im really stumped on this one, my fuel pump is pushing fuel and motor is turning over, it has compression equal in all 4 cylinders. Given that it is fuel injected, is there a fuse or a relay for the injectors? im pretty sure its getting spark but nothing is turning over
blacc_ej1
11
Mar 17, 2009 10:11 AM
harley06
Apr 16, 2008 06:04 AM
1bar_ek
Apr 18, 2006 02:32 PM
JDM CTR EK
Apr 4, 2005 09:15 AM
jdmkrazie
Jun 1, 2004 09:16 PM
