help knock sensor
Old Nov 13, 2007 | 01:56 PM
sc95delsol's Avatar
Default help knock sensor
does this mean my rod is going bad???????????????????????
Old Nov 13, 2007 | 02:01 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: help knock sensor (sc95delsol)
Pretty vague topic bro.
Are you throwing a check engine code for knock sensor?
If you are chances are the wiring is an issue, you're missing the knock sensor, or your knock sensor is bad.
What year/make/model is the car?
What ECU you running?
What engine are you running?
Help us help you!
Old Nov 13, 2007 | 02:02 PM
sc95delsol's Avatar
Default Re: help knock sensor (B18C5-EH2)
b16 sir 2 p30 ecu 95 del sol
oh and it just started today
Old Nov 13, 2007 | 02:12 PM
sc95delsol's Avatar
anyone have any ideas????
Old Nov 13, 2007 | 02:24 PM
Ketone's Avatar
Check the knock sensor to make sure the clip has not broken off. I have had this happen twice.
Old Nov 13, 2007 | 02:26 PM
sc95delsol's Avatar
Default Re: help knock sensor (Ketone)
where is the knock sensor
Old Nov 13, 2007 | 03:11 PM
Ketone's Avatar
its located on the back of the block, under the intake manifold, between number 1 & 2 cylinder.
Old Nov 13, 2007 | 05:08 PM
sc95delsol's Avatar
turns out somehow it came unplugged, i repluged it in and it is working fine now thx all
Grnade
May 2, 2005 08:45 PM
CandyRedHatch
May 5, 2003 08:31 AM
