licking problem!!!
The reason your car is licking water is because it's thirsty
Sorry someone had to do it.
Well any who..... What front corners? The lights? The floor boards? Windshield? Any pics? Most likely just a bad seal where ever it is. Just start to look for the leak, if it's not raining use a hose to find the leak. Then just use some silicone to plug it up or replace the part. If you don't know what the part is called just take it with you and they'll help you find what you need at the parts store.
Sorry someone had to do it. Well any who..... What front corners? The lights? The floor boards? Windshield? Any pics? Most likely just a bad seal where ever it is. Just start to look for the leak, if it's not raining use a hose to find the leak. Then just use some silicone to plug it up or replace the part. If you don't know what the part is called just take it with you and they'll help you find what you need at the parts store.
