Installing JDM EG6 white face cluster
Old Nov 13, 2007 | 12:00 PM
hatchy69's Avatar
Default Installing JDM EG6 white face cluster
The 2 big connectors on both ends of the cluster are in....there's a yellow adapter and a white adapeter that won't go into these 2 empty ports in the back of the cluster....do I need those or no becuase the adapters and the port behind the the cluster don't match up? Will it effect the clusters normal working condition?
Thanks in advance
Old Nov 13, 2007 | 12:44 PM
deckster333's Avatar
Default Re: Installing JDM EG6 white face cluster (hatchy69)
one is srs i forgot the other.
Old Nov 13, 2007 | 12:55 PM
23-10's Avatar
Default Re: Installing JDM EG6 white face cluster (deckster333)
Traction Control maybe?
Old Nov 13, 2007 | 03:38 PM
BlueIntegraBoy's Avatar
Wow, rare to have an SRS JDM EG6 cluster. For the white plug, they are usually on USDM clusters for the shift light. You don't need to plug them in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 23-10 &raquo;</TD></TR><TR><TD CLASS="quote">Traction Control maybe?
Nope, these are green
Old Nov 13, 2007 | 06:39 PM
hatchy69's Avatar
Default Re: Installing JDM EG6 white face cluster (BlueIntegraBoy)
Yeah im pretty sure your right because the ports behind the cluster are green. I left those to adapters unpluged and the cluster works fine...thanks for your help guys
NOCOASTcoupe247
Feb 19, 2013 03:46 AM
dungsta
Acura TSX
13
Aug 3, 2008 08:16 PM
PSU
17
Jun 1, 2002 12:46 PM
