FS: built sleeved b18b and ctr head from honda
Fully Built LS Block
B18B1 Block
AEBS T-Sleeves 86mm
JE Pistons 9.1:1
Total Seal Piston Rings
Eagle H-Beam Rods
VTEC Oil Pick up
VTEC Oil Baffle
VTEC Oil Pump (Type -R)
VTEC Water pump
VTEC Dowel Pins
Brand New Honda Timing Belt
Golden Eagle Head Studs
Alternator
Everything installed professionally, all clearances checked, Engine balanced, comes with all normal parts like the oil pan, tensioner,coolant pipe, thermo housing, pretty much ready to go.
PRICE$1,600
*SOLD*PR3-3 EK9 Civic Type-R Head*SOLD*
Head comes COMPLETE:
Mild Intake Port
Port Matched CTR intake manifold
Throttle body
CTR Camshafts, cam gears
everything else is stock (CTR)
All sensors on head and intake manifold including map, and TPS on throttle body
Intake Manifold Spacer (up to 30 degrees cooler, In. Temp)
High Volume Fuel Rail w/ Guage
NO INJECTORS Look down on the list!!
*SOLD*PRICE $900 O.B.O*SOLD*
Delphi 1000cc, 95lb Injectors (Flow tested!)
Lowered Price $200
*SOLD*Hydraulic GSR Tansmission/Transaxle with Phantom Grip "LSD"*SOLD*
Price $400
OBDI VTEC Distributor w/MSD SS Coil w/Wire
Price $120
B-series axles (BOTH, Great condition)
Price $80 for both
Modified by mymeatb18" at 5:33 PM 11/25/2007
Modified by mymeatb18" at 12:56 PM 11/27/2007
Modified by mymeatb18" at 10:16 AM 11/29/2007
Modified by mymeatb18" at 1:17 AM 11/30/2007
Modified by mymeatb18" at 8:00 PM 12/26/2007
Modified by mymeatb18" at 6:57 PM 1/8/2008
B18B1 Block
AEBS T-Sleeves 86mm
JE Pistons 9.1:1
Eagle H-Beam Rods
VTEC Oil Pick up
VTEC Oil Baffle
VTEC Water pump
VTEC Dowel Pins
Alternator
PRICE$1,600
Mild Intake Port
Throttle body
Lowered Price $200
Price $400
Price $120
Price $80 for both
You are pretty close to one of my friends in Jacksonville too. Email me with the info to jeff95hatch@googlemail.com
Emshhh
Mid-Atlantic (Sales)
12
Sep 28, 2010 07:22 AM
