Loss of power at highway speeds 1997 accord
Old Nov 13, 2007 | 08:00 AM
eggers's Avatar
Default Loss of power at highway speeds 1997 accord
Have a 1997 honda accord 4 cyl. driving at about 60-65 engine loses power(hestitates). If i press on gas pedal car bucks. upon coming off highway everything fine back on highway starts problems. driving around city no poblems
replaced plugs, rotor ,cap , fuel filter , adjusted values
any ideas? mechanic can't get car to do it wait until it happens more frequently
nb this all started after changing 02 sensors
don
Old Nov 13, 2007 | 08:05 AM
Duane_in_Japan's Avatar
Default Re: Loss of power at highway speeds 1997 accord (eggers)
I would start with a fuel pump diagnosis, will require an oscilloscope and amp clamp and a tech who knows how to read an amp ramp OR go for a drive with pressure and volumn tester hooked up. I think you may be running out of fuel at higher speeds. You can try a Dead Head test, clamp off the return fuel line to the tank after the fuel rail (after fuel injectors). Some guys frown on the Dead Head test.
Old Nov 13, 2007 | 08:14 AM
eggers's Avatar
which would mean new fuel pump?
Old Nov 13, 2007 | 05:27 PM
Never replace parts without testing first. See above.
erh
Nov 11, 2013 03:41 PM
jeebus520
Jul 9, 2010 10:15 AM
Bedicheck
Jul 19, 2009 10:43 AM
C_H_A_D
Aug 28, 2006 05:09 PM
mastar91169
Jun 30, 2006 12:35 PM
