intake...
the f22 intake will fit on the h22 throttle body?
or the f22 tb fit on the h22 im?
you're being a bit too generic but an intake for the f22 will fit on the h22 tb, it's just smaller than the h22 intake (piping diameter)
I'm not completely sure what you are asking... Are you asking about a intake (short ram, cold air) or are you referring to the intake manifold?
What year/car/engine do you have and what are you trying to do?
yea the intake pipe.....i hear that the f22 intake pipes will fit but they will be a little small or restrictive of airflow for the h22....so i was thinking of getting the h22 intake(short ram)....i have the F22 engine right now...but i don't won't to buy 2 short rams so i was thinking of just getting the H22 short ram...and then when i get the H22 i will just bolt it up to it...
A 3" CAI or SRI tube will match up to whatever size TB you want it to fit. As long as you have the proper coupler. If your worried about restriction all CAI & SRI have a reduced coupler. From 3" down unless you have yourself a 76.2 mm throttle body
If I were you I would buy the CAI for the Make /Model/Year of your Accord you have. Then when you get your H22 find a rubber coupler that fits the H22 throttle body. That would be easier than trying to make a 3" aluminum tube bend to fit your car. Just a side Note* I believe that there is only about 2-3mm difference in the outer diameter of the H - F TB's. So the F coupler should stretch fit to the H TB.
Modified by GhostAccord at 3:46 PM 11/13/2007
the engine bay of the Prelude and Accord are pretty close in design/shape/size. I would think the piping should fit. though I've never tried personally.
