gsr or ls fuel pump
I need to replace the fuel pump on my 92 DA but I did a swap and now it has a gsr from a 95, so my question is should I just put a regular fuel pump from a 92 LS or should I get the one for the 92 GSR for the 1.7L, or does the ones from the DC models bolts right up on the DA body style, I know the part numbers are diffrent from a 92 LS and a 92 GSR from the dealer but anyways just let me know what you guys think.
no they are different. if you want a bigger one you can get one of these they are cheap enough. http://www.lightningmotorsport...s.htm
cashmoneystu
Jun 10, 2004 05:28 PM
ls fuel pump is fine... making more power then get a better one ie aftermarket
