ROOF molding/weather strip
as the title says , ive searched but have come up short on how to REPLACE the moldings or weather strips that are on the roof of the 92-95 civic's ( ive got a ej1)...
it runs from front to back on both pass and driver!!!!!
There is a clip at the front and the rear in the run channel. The clip on the molding looks like an old time thermometer (like a circle attached to a rectangle). If you slide the molding in one direction it should pop out and you can lift the molding off the roof. If you plan on replacing them anyway, get the new one and you'll see exactly how and where they are clipped. If you need anything further I'll be happy to help. I hope that clears things up. Good luck!
00-501itrspec
Nov 3, 2005 04:12 AM
RR98ITR
90
Oct 12, 2005 04:21 PM
