help me!!!!!!!
check dis!! my car sat for three months alright.
den started it up not to long ago.ran it around the block pretty hard.
then the next day started it. drove it, and it had no power it would bog out and spit when i gave it throttle and now it would idle at 500 or less..battery is good plugs r good and all dat stuff.did a compression check dats good.....any1 know wassup with my car? its a gsr crx.......need help on dis!!!!!!! got some ideas anyone.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsredcrx1 »</TD></TR><TR><TD CLASS="quote">check dis!! my car sat for three months alright.
then the next day started it. drove it, and it had no power it would bog out and spit when i gave it throttle and now it would idle at 500 or less..battery is good plugs r good and all dat stuff.did a compression check dats good.....any1 know wassup with my car? its a gsr crx.......need help on dis!!!!!!! got some ideas anyone.</TD></TR></TABLE>
so you started it after 3 months and ran it hard right off the bat?
Cant Help you with the prob but it sounds exactly the same as happened to my crx twice after letting it sit for a few months. Both times the prob fixed its self after playing around under the hood for a few hours the first time it happened I even took it to a mechanic and got told it would need a head rebuild, glad I didnt go ahead with it because as long as I dont let it sit it doesnt miss a beat. I also asume a GSR has a B16 mine is D (from Australia we dont have GSRs over here)
throw in full tank of fresh gas and injector cleaner then see what happens. Next time you store, ad some Stabil, doesnt hurt. Give this a try and report back. Worked for me when i stored a winter without stabil and had same symptoms.
Edit, try THIS instead of dis. I thought u were talking distributor at first even though its normally dizzy for short. Helps to know EXACTLY what ur talking about.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by traxxasx »</TD></TR><TR><TD CLASS="quote">Lmao vtec doesent kick in until the car is fully warmed up.
Lmao...ice cold.....</TD></TR></TABLE>
I was thinking the same thing. Try the gas ans injector cleaner like earlier in the thread that should fix it.
I now have a headache from you butchering the english language so much. thanks
From: Where the wild things are in, NY, United States of America
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIRX »</TD></TR><TR><TD CLASS="quote">
phbbbt, headache... i had a stroke after the first 12 words.
OP, try to get some gas treatment / injector cleaner in there, condensation is a bitch
good luck.
</TD></TR></TABLE>phbbbt, headache... i had a stroke after the first 12 words.
good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ComeOnKip »</TD></TR><TR><TD CLASS="quote">
good luck.</TD></TR></TABLE>
slowB20ej8
Jan 3, 2008 09:42 PM
MasterShake
Jul 16, 2007 09:53 PM
carlosd68
Jul 8, 2006 07:51 PM
mikegeezy
Apr 9, 2006 09:17 AM
