Help with Burnt valve
Old Nov 12, 2007 | 04:06 PM
JasonST's Avatar
Default Help with Burnt valve
So this 90 civic 4 door i purchased recently has been running on 3 cylinders. I did the compression and leakdown check and the cylinder that wasn't running had only bout 10 psi, the leakdown test revealed air to be rushing out of the intake/ throttle body so i assumed it was a bad intake valve. Well today I took the head off, inspected the valves to find out that 1 of the exhaust valves was cracked/broken off, and all the exhaust valves are very very white. All the intake valves look fine though. So I'm vonfused to see why I have a burnt exhaust valve when the leakdown revealed a bad intake valve, and yes I made sure the engine was at TDC for that cylinder. Any help would be appreciated. Thanks.
-Jason
thegatekeeper14
Dec 27, 2010 09:40 AM
fleetw00d
Jan 9, 2010 03:16 PM
92integraVTECgsr
10
Oct 17, 2009 11:13 PM
mannydhanju
Feb 28, 2009 11:33 AM
SkRiBLaH
May 9, 2006 01:05 PM
