fs/ft 300+whp mk2
Engine
2.0L ABA bottom end (Rebuilt)
1.8L 16v head w/3 angle valve grind (Rebuilt)
Euro Nation custom intake manifold
Euro Nation custom turbo manifold
Euro Nation 3" down pipe Euro Nation 2.5" charge pipes
Turbonectics t3 BALL BEARING TURBO 60-1 STG 5 .58 A/R (new)
TiAL 38mm external wastegate
TiAL 50mm blow off valve
ARP head studs
ARP rod bolts
8 x 25 front mount
3'' magnaflow exhaust(NEW)
apexi turbo timer
____Drive Train
O2A cable shift transmission swap
Peloquin Limited Slip Differential
Spec Stage 4 clutch
lightened G60 flywheel
_____Fuel System
Megasquirt’n’spark (all new custom wiring harness and connectors)
60lbs Seimen Deka injectors mounted in a Audi TT fuel rail
GM 3 Bar MAP sensor (new, AC Delco)
CIS fuel pump/surge tank/fuel filter
_____Suspension/Wheels/Brakes
Weitec Coilovers
16" Konig Traffik (wheels)
Dunlop SP Sport FM901 (tires)
10.1" front brakes
8.9" rear disc brakes
Exterior:
Montana Green paint
E-Code H4 Hella headlights (OEM yellow bulbs, w/stone gaurd covers, all new)
Custom yellow center lights (yellow stone gaurds)
OEM Quad headlight grill and core support
Euro VR6 front lip (factory VW parts)
Interior:
Recaro 16v full gray seats
Momo steering wheel
Momo shift ****
VDO 0-30PSI boost gauge
no rear seats but i do have the 'cargo tray'
Optima "Red top" sealed battery
black carpet, dash, black/grey door cards
NO Air conditioning (non-AC car), NO power steering (manual rack).
it ran a 13.00 @ 115mph on the 16" wheels/tires pictured. this GTI hauls ***!!!
throw some slicks on it and add some race gas at 22psi im pretty sure it will run 11's...
show me what you have to trade or make me an offer
Modified by -mk2turbo- at 5:29 PM 11/12/2007
ARP head studs
ARP rod bolts
8 x 25 front mount
apexi turbo timer
____Drive Train
Spec Stage 4 clutch
_____Fuel System
Weitec Coilovers
10.1" front brakes
Exterior:
Montana Green paint
Interior:
Momo steering wheel
Momo shift ****
NICE!
