1990 accoed EX power sterring or rack leak?
Old Nov 12, 2007 | 02:39 PM
stigedis's Avatar
Default 1990 accoed EX power sterring or rack leak?
I had a similar problem about 1 year ago..had a leak under the car. When steering it made an occasional noise (like while turing in a clover leaf off ramp). Had to have the pump replaced. Problem and leak fixed. Now about one year later the same is happening. The pump sounds fine. No noise at all. The houses that connect to the pump look dry. Alternator is wet. But very leaky underneath. Hard to determine where it is coming from. Pulleys and all very wet. How do I determine if the pump is bad? And what are symptoms of a leaky rack? Is a rack leak a big project? I think if its the pump I can replace that as it is very accessible. But the rack?
Any suggestions or help would be appreciated..thanks..
Old Nov 12, 2007 | 07:27 PM
gianinline's Avatar
If the rack is actually involved on this.... it's a little difficult to work on it, not much space to fit your tools and stuff, but it's nothing impossible. I think the worst of all was disconnecting the steering at the firewall from inside the car (that's how i did mine), it was tricky to reach that bolt.
Rotting Prelude
Mar 12, 2018 11:48 AM
bestofthe80s
May 30, 2017 09:57 PM
wallendiaz
Nov 23, 2012 06:02 AM
jimulon6
Jan 16, 2009 10:16 AM
