95 Honda Accord Heater Issue
Old Nov 12, 2007 | 01:33 PM
glsspder's Avatar
Default 95 Honda Accord Heater Issue
I have a 95 Honda Accord and when i turn onthe AC it blows cold just fine, but if i turn the temparature dail to heat it still blows cold, Any idea on where i should look? I have already taken the dash and and the temp dail is functioning correctly. Any Help would be appreciated.
Old Nov 12, 2007 | 02:55 PM
kjmoy's Avatar
Default Re: 95 Honda Accord Heater Issue (glsspder)
Make sure antifreeze in the reservoir and the radiator are fill to spec. Good luck.
Old Nov 12, 2007 | 03:05 PM
glsspder's Avatar
Default Re: 95 Honda Accord Heater Issue (kjmoy)
all fluids are already checked and ok.
Old Nov 12, 2007 | 07:41 PM
Homesickelian's Avatar
probably the thermostat being stuck open cooling your system too well and taking forever for your heat to come on. Does your temp needle stay low for a while? once it's warmed up I think the needle should be a little past half.
Old Nov 12, 2007 | 07:49 PM
Ronin1's Avatar
"I have already taken the dash and and the temp dail is functioning correctly. Any Help would be appreciated. "
I am not sure if you mean that you have checked the door that diverts air from the A/C evaporator (cool air) and allows air from the heater core to blend in varying degrees from warm to hot. If not check that door as you move the temperature control. After the engine is warmed up I would feel the heater hose in the engine compartment where it goes through the firewall to see that it is at least warm, if not hot.
The next steps depend upon what you find so give that a try and let us know what you find.
mrsrubis
12
Oct 19, 2020 05:42 AM
luvmihatch
Mar 5, 2013 04:49 PM
Chgoaccordguy
Jan 10, 2008 05:55 PM
jboy210
Dec 20, 2007 03:57 PM
