Quarts of ATF for tranny flush?!
Old Nov 12, 2007 | 12:33 PM
m1ndless's Avatar
* B A N N E D *
Default Quarts of ATF for tranny flush?!
I need to flush (drain-and-refil) my tranny but I cannor remember how many quarts are needed for each refil, is it 4?
Thanks!
Old Nov 12, 2007 | 12:39 PM
TheMuffinMan's Avatar
He knows where you live!
I want to say I used like 3 3/4 (with 4 bottles obviously) in my MT, I can't see the auto holding much more.
It should be in the owner's manual
Old Nov 12, 2007 | 12:44 PM
CD5 Jeebies!'s Avatar
From: Free bullets if you find me sucka, Washington
Default Re: (TheMuffinMan)
I thhink we used 7 when we did my ex girls accord.....2 to flush and 4 1/2 to fill? sounds right.
Old Nov 12, 2007 | 01:23 PM
JimBlake's Avatar
Default Re: Quarts of ATF for tranny flush?! (m1ndless)
Should be about 2.5 quarts for each drain/fill. If it looks clean on the dipstick now, & doesn't smell bad, you can probably get away with one cycle.
Old Nov 12, 2007 | 01:52 PM
m1ndless's Avatar
* B A N N E D *
Default Re: Quarts of ATF for tranny flush?! (JimBlake)
It looks old and it smells a little, but not burnt, but it has been 20k miles so I need to do it, I can feel that it needs it..
So I need 6 quarts for 2 drain and refils then, right? All I do is drain out the old fluid, replace with new, drive around for a bit, then drain and refil again and then I am good to go, right?
Old Nov 12, 2007 | 05:38 PM
JimBlake's Avatar
You got the procedure. Hard to say whether you'll get away with 5 quarts. Safer to have 6 on hand, but it's easy for me to spend your money....
The 2nd time you drain, watch how clean it comes out & judge for yourself whether you need to do any more drain/fills. You'll also see how much crud is stuck to the magnet of the drain plug.
I had a '98 & did a single drain/fill every 30k miles & it was OK. Not very dusty/dirty where I live & it had a fair amount of highway miles, so I guess mine had an easy life. YMMV.
slatermvp
Apr 13, 2012 04:17 PM
m1ndless
Aug 29, 2007 06:05 PM
Elwuudz
Jan 15, 2006 07:54 PM
upinsmoke
Dec 1, 2005 02:46 PM
tylerdurden
12
Jan 17, 2003 10:46 AM
