JUN3 cams or Skunk2 cam with JDM ITR pistons: Cam settings Maxium adv/retard
Old Jun 24, 2002 | 05:47 AM
TRuST's Avatar
Default JUN3 cams or Skunk2 cam with JDM ITR pistons: Cam settings Maxium adv/retard
Let's say that you have B18c1 with JDM ITR pistons and a stock head gasket, how much can you advance or retard the cam timming without having valve to piston contact with the Skunk2 stage 2 cams and/or the JUN 3 cams.
Also, what kind of cam settings are you guys running with the JUN 3 or S2 stage 2 cams ?
Old Jun 24, 2002 | 10:50 AM
TRuST's Avatar
Default Re: JUN3 cams or Skunk2 cam with JDM ITR pistons: Cam settings Maxium adv/retard (TRuST)
sgT's Avatar
sgT
clay the motor and find out
if you arent willing to do that then you shouldnt use those cams
Old Jun 24, 2002 | 10:55 AM
Big Phat R's Avatar
claying is the only way of determining the answer to your question. you can't use other people's measurements because all engines are slightly different with aftermarket cams. Adjustable cam gears only compound variability.
Old Jun 24, 2002 | 11:10 AM
TRuST's Avatar
Default Re: JUN3 cams or Skunk2 cam with JDM ITR pistons: Cam settings Maxium adv/retard (Phat Bastard)
Anyone, got any recommendation for a Machinists scale and clay when claying the motor. I looked up C-speed Racing article is this enough to learn how to clay your motor.
http://www.c-speedracing.com/howto/claymotor/clay.html
How much does a machinists scale cost ?
shocker911
Aug 22, 2012 04:57 AM
9tailsfox
28
Feb 23, 2012 08:11 AM
Dasanib20T
Jul 6, 2008 11:44 PM
TallKyle
Jun 19, 2007 08:57 AM
Hybrid96EK
Dec 2, 2003 10:12 AM
