Gsr EG Axle Problem. Pics Posted
Old Nov 12, 2007 | 10:21 AM
anotherwhitehatch's Avatar
Default Gsr EG Axle Problem. Pics Posted
Alright i removed the axles from my b18c1 swapped eg and put them next to the new ones i got from advance. they definitely dont match up. i looked up the part number to see if they gave me the wrong ones and they supposed to be correct. I even cross referenced them from other b-series models.
The bottom new ones are gsp new cv halfshafts item #NCV21525 for any b-series motor but for my sake b18c1,
The top one is the old torn boot axle from passenger side. the inner joint appears identical but the outer joint is shorter as you can see
[IMG][/IMG]
[IMG][/IMG]
Can anyone tell me what i got to get (hybrid axles from raxles or hasport)
Could i have a different transmission
Old Nov 12, 2007 | 10:23 AM
Bazza's Avatar
could be that.. or you could go bring them your old ones and they can find you ones that are the same as your old ones try bringin em in and go from there.
Old Nov 12, 2007 | 10:27 AM
BlueIntegraBoy's Avatar
Default Re: Gsr EG Axle Problem. Pics Posted (anotherwhitehatch)
Well all 90-01 Integra passenger side axles are the same, except for being ABS or not. So, definitely has nothing to do with your tranny. Bring back that axle along with your stock axle and get another axle. Compare the new axle with the stock.
Old Nov 12, 2007 | 11:08 AM
4drgsr96's Avatar
i had the same issue when i went to replace my torn boot axles with new ones from autozone. what i figured is the the overall length was shorter because the boot is actually SEALED as opposed to the torn boot which extended out because of the lack of vacuum inside the boot... so i just installed them and called it a day. no problem what soever.
Old Nov 12, 2007 | 11:57 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: Gsr EG Axle Problem. Pics Posted (4drgsr96)
If the axle has brand new outer joints they might just appear to be different, but actually work the same.
There are no "special" axles needed for a B18C1 into an EG. Any 1994-2001 Integra, 94-97 Del Sol VTEC, or 99-00 Civic Si axles will work just fine.
...and ABS doesn't matter either unless you have a 1994 Si w/ABS - then you must get an ABS ring'd axle. Otherwise ABS or not doesn't matter.
Old Nov 12, 2007 | 01:54 PM
Default Re: Gsr EG Axle Problem. Pics Posted (B18C5-EH2)
alright, not saying much, but the advance guys were stumped. said there is some sort of varience from 93 to 94 honda and acura models but were inconclusive on an axle that'd fit. possibly that the joint expanded from overuse but there is a 1.5 inch difference and i want to be certain. there was only a small tear in the boot before.
Old Nov 12, 2007 | 02:00 PM
BUDtoker's Avatar
try putting them in and if they dont work or go clunk when you throw it in reverse take em back and match them up at autozone if they dont have the right part try carquest ect till you end up at hte dealership!
Old Nov 12, 2007 | 09:09 PM
Default Re: Gsr EG Axle Problem. Pics Posted (BUDtoker)
alright the driver side one looked exact so i put that one in.
i;m going to go try to just put the other side in (the skrewy one)
be back in twenty for update
Old Jan 12, 2010 | 07:45 PM
eg6girl's Avatar
im having the same issue with my gsr swapped eg as well!!! i want to know who or where i can get replacement axles? or which will fit? thanks
Old Jan 12, 2010 | 07:49 PM
d16turbocoupe's Avatar
i had an eg gsr hatch and the integra gsr axles should fit just fine with the eg.
Old Jan 12, 2010 | 07:55 PM
eg6girl's Avatar
how much of a diffrence is there among gsr and ls integra axles??? because i think the stupid guy at autozone gave me some ls ones
Old Jan 12, 2010 | 08:10 PM
eg6girl's Avatar
[IMG][/IMG]
this is the exact situation im in.... plz help
Old Jan 12, 2010 | 09:28 PM
thumper64's Avatar
They are the same, just the GSR had ABS, but I believe the LS had ABS too, an RS didn't... but it's still the same length.
Old Jan 12, 2010 | 10:11 PM
mrharmonic's Avatar
try moving it in a circular motion while instaling it should fit bro
Old Jan 13, 2010 | 03:23 PM
CX Hatch's Avatar
Any update on your progress? I am having the same problem. But I have RS axles. They don't seem long enough on the driver side when matched up.
Old Jan 13, 2010 | 03:35 PM
BryanM.'s Avatar
Resident Gearhead
Integra (LS, RS, GS and GS-R) axles are all the same dimentions. The only difference is if the ABS ring is present or not.
Aftermarket axles are hit or miss. Always bring your old axles into the store to compare length, spline count etc etc...
Old Jan 13, 2010 | 03:47 PM
CX Hatch's Avatar
Sorry to hijack the thread, but I figured since I'm installing a GSR in an EG, it fits to post.
The GSR axle looks longer, but as you can see, the RS axle boots are compressed, do they ever open up to the size of the GSR axles?
Old Jan 13, 2010 | 04:40 PM
BryanM.'s Avatar
Resident Gearhead
The inner boot of the left axle looks a bit elongated, and the inner boot of the right one looks compressed.
I stand by my previous post.
Old Jan 13, 2010 | 05:45 PM
CX Hatch's Avatar
I tried giving the RS axle a slight pull to spread open the boot, but it doesn't budge. Should it still bolt up correctly to the hub?
Old Jan 20, 2010 | 10:48 PM
eg6girl's Avatar
thanx thumper64 my prob has been solved
EusebioSam19
Jun 30, 2010 02:22 PM
Mavrick
Nov 11, 2005 11:14 AM
penney
May 30, 2005 06:58 PM
coseal
May 4, 2004 07:37 PM
coupedup
24
May 2, 2002 07:36 PM
