checking cel codes...
Who is the conversion made by? There should be two wires on the conversion that you can run to a switch. if you flip the switch than the cel will show.
there are not hiiked up...
so what do i do..
1 yellow and 1 black wire.
put black on one side of switch and yellow to the other side
"or"
put black and yellow on one side and hook the other side to a ground..
so what do i do..
"or"
No just hook one up to one side of the switch and hook the other up to the other side. Or you could just hook them together and turn your key on.
Here is instructions from rywire, But the color codes only match their harness. Usually people use different color wires.
http://www.rywire.com/store/im...r.gif
thanks 1 Fly SI for the help
got the code now serching for what it is.... thanks
i think 1 and 6
edit---->code 6 i fixed it just put a new plug on......
Modified by 1989rexsi at 5:35 PM 11/13/2007
i think 1 and 6
ie: toggle the switch and the cel goes out and then comes on for 2 sec and then goes out for 5 seconds and repeat. what is this
code 1 or what
code 1 or what
Dc4iNtEgRa
Mar 3, 2008 04:13 PM
ViperRedCRX
14
Dec 15, 2002 02:14 PM
