LS VTEC ITB'S
IM PLANNIN ON GOIN ALL-MOTOR LS VTEC
IM GETTIN A STROKER KIT N I WANNA BORE IT OUT
CONSIDERING I CAN GO BIGGER NOT SURE WAT
SIZE I CAN DO?
I WAS THINKIN MAYBE I CAN GO 84MMBORE X 95MM STROKE
WHICH WILL SET ME TO A 2.1L MY QUESTION IS
WAT COMPRESSION RATIO WOULD CLEAR OR BE SAFE FOR IT
AS FAR AS ME PUTTIN SKUNK2 PRO2 CAMS IN A GSR HEAD???
IF ANYONE HAS AN OPINION PLEASE LET ME KNO
SIZE I CAN DO?
if you wanna go 84mm on a ls you'll have to get the block sleeved but i think it may be possible if i were you i would just get a b20 if do not wanna sleeve im buildin quite a few b20s and if had no problems and these are allmotor.
i would suggeswt get the head p&p valve train but it should be good up to 12.5to 1 is what i have done
the most u can bore out on a stock b series block without re-sleeving is 82mm, the most i would suggest goin is 81.50mm, jus to be on the safe side though, its all up to you though
mskibbz-T
Nov 1, 2002 12:39 PM
