zc with HF engine harness
Old Nov 12, 2007 | 07:39 AM
zccr-xsi's Avatar
Default zc with HF engine harness
hey guys in just about done reinstalling my zc in a crx hf.i used the hf harness and i noticed it didnt have the 2 wire clip for the sensor on the back of the mani.(not evac)will it be ok to leave it unhook or should i grab the clip off the si harness and wire it up?if so what pin on the ecu does it go too?and i got another prob. on the bracket that mounts to the firewall that holds the map sensor and that other sensor? well on the hf the the map sensor will work but that other sensor has a 4 wire clip can i just depin the 2 wires i dont need ?will it run like it should if i do depin the 2 wires i dont need heres a pic of the sensor im talking about.
Modified by zccr-xsi at 8:49 AM 11/12/2007
Old Nov 12, 2007 | 07:41 AM
90efhatch's Avatar
I didnt hook up that sensor on my SI and I get no codes and it runs fine. If you want to hook it up then I could find out where the wires run to but I am not sure right off.
you should be able to depin and hook up the other sensor. I have never had to mess with that one so I am not sure.
Modified by 90efhatch at 9:01 AM 11/12/2007
bussey_03
Jul 7, 2010 02:25 PM
QuickRexSi21
Jul 15, 2006 05:19 PM
so-cal-ef
Oct 29, 2005 11:02 AM
1990hondaHF
13
Jul 23, 2002 12:15 PM
