rough / low idle (94' EX, D16Z6)
Old Nov 11, 2007 | 09:03 PM
office888's Avatar
Default rough / low idle (94' EX, D16Z6)
Symptoms:
Rough / Low Idle (RPMs barely register on tachometer) AFTER car is warmed up. Car occasionally stalls out completely and is a little tough to restart.
Background:
Car has 250,xxx miles, D16Z6, brand new head gasket. Car was sitting for 3 months with a half-tank of gas. I filled up the tank after I got it running with V-Power 93 + HEET Anti-Water.
Any ideas? Bad IACV?
---richard
Old Nov 12, 2007 | 03:53 AM
cjk95delsolsi's Avatar
when was the last time you gave your car a tune-up?
Old Nov 12, 2007 | 08:47 PM
Dee_SydekicK's Avatar
Default Re: (cjk95delsolsi)
i have sort of the same or the same problem. mines will start up fine then after a while it jus idle low like under 1. i still cant figure it out.
Old Nov 13, 2007 | 04:18 AM
burgandybeast's Avatar
Default Re: (Dee_SydekicK)
me three. any info on this much needy.
Old Nov 13, 2007 | 05:43 AM
When is the last time you have given your car a tune-up? spark plugs, plug wires, dist cap rotor, pcv valve?
Old Dec 4, 2007 | 06:23 PM
DARKB20's Avatar
Default Re: (burgandybeast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by burgandybeast &raquo;</TD></TR><TR><TD CLASS="quote">me three. any info on this much needy. </TD></TR></TABLE>
me four
Old Dec 4, 2007 | 06:25 PM
SOHC_4dr's Avatar
when was the last tune up! lol
Old Dec 4, 2007 | 06:32 PM
Amped's Avatar
Default Re: (SOHC_4dr)
Any codes? Diagnostic codes that is. They serve a purpose you know. There could be 20 different problems going on with your cars. To figure it out you have to narrow it down to a specific circuit or area. I think there is helpful knowledge in the FAQ's on idling problems. I have seen throttle position sensor plugs with loose connections, carbon buldup in the throttlebody, low battery voltage, IACV problems are common too. i could go on and on.
Old Dec 4, 2007 | 06:44 PM
87dohcRS's Avatar
Default Re: rough / low idle (office888)
make sure your o2 sensor is plugged in and there are no shorts or melts in the wire, i have a 98 dx with a z6 running a p28 ecu in it and somehow in the swap i hooked up the o2 sensors backwards ( obd2a has 2 o2 sensor reads and obd1 has 1 ) i had just done timing belt and water pump and head gasket so i knew my work was good , but it ran like crap in the morning . after it warmed up it seemed ok but ran rich , NEVER GOT A CEL !!! the header i have has 2 o2 ports so i decieded just to keep them both in , i switched the plugs and bam my problem went away , also make sure your not arching from the back of your spark plug wires , ive seen that happen!
angrysmileyface
Oct 6, 2012 01:22 AM
krisc09
14
Jul 21, 2009 08:11 PM
killmeamerika
Mar 14, 2008 06:45 PM
defkid999
Oct 17, 2006 10:12 AM
92civeg
Feb 19, 2006 05:55 PM
