Stock civic rad with B18B?
Old Nov 11, 2007 | 08:04 PM
Lord Milferdeen's Avatar
Default Stock civic rad with B18B?
Can i run my stock rad with a B18B swap? Will I have to worry about cooling issues? Any help would be great
Old Nov 12, 2007 | 12:40 PM
egjdmcivichatch's Avatar
Default Re: Stock civic rad with B18B? (Lord Milferdeen)
will work fine just make sure the hoses fans are good etc...
Old Nov 12, 2007 | 12:45 PM
crazyguy's Avatar
yea u can..i am running b16a with stock d series rad and fan..
Old Nov 12, 2007 | 12:51 PM
JKov240's Avatar
Default Re: Stock civic rad with B18B? (crazyguy)
I've been running the stock Civic radiator on my GS-R swap for a year with no problems. I just put two clamps where the hose connects to the radiator because the Integra hoses are a bit bigger than the Civic ones.
Old Nov 12, 2007 | 01:31 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: Stock civic rad with B18B? (JKov240)
I ran my wife's B16A2 1992 Si hatch on the stock Civic radiator for 5 years with zero cooling issues ever.
And JKov240 is right - yu'll be running Integra radiator hoses, which are larger diameter than the civic radiator outlets, so buy screw-type hose clamps to tighten the hoses onto the smaller Civic rad. outlets.
Old Nov 12, 2007 | 02:29 PM
BUDtoker's Avatar
Default Re: Stock civic rad with B18B? (B18C5-EH2)
if you got the money than buy a proper aluminum rad you can score a decent one on ebay for around 150 bucks bolts right on no issues with it being bigger than stock,but now you have a peice of mind knowing your rad is new and has extra capacity and that is always a good thing,makesure you change water pump and thermostat it would be a shame to mess your engine up cause some dumb part failed
Old Nov 12, 2007 | 02:32 PM
93egSLEEPER's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy &raquo;</TD></TR><TR><TD CLASS="quote">yea u can..i am running b16a with stock d series rad and fan..</TD></TR></TABLE>
x2... pointless to buy anything else unless your going for looks.
Old Nov 12, 2007 | 02:57 PM
BUDtoker's Avatar
Default Re: Stock civic rad with B18B? (93egSLEEPER)
bigger radiator means better cooling capabilities it cools off the engine faster than stock and has more cooling capabilities than a cooper rad becuse it stays at 160 cooper does not have as good of cooling capabilitys stays at 180 and the added bonus if you ever leaked coolant from a honda it dissapears quickly cause of the small rad so if you do leak you have more time before it becomes a big problem! and it looks really sharp
Old Nov 12, 2007 | 05:40 PM
Default Re: Stock civic rad with B18B? (BUDtoker)
Thanks budtoker. I never knew a bigger rad meant better cooling All kidding aside thats fantastic news cause i cant afford another rad yet
Old Nov 12, 2007 | 05:42 PM
Eran's Avatar
HT White Ops
When I put my B18B into my 97 CX, the stock radiator inlet/outlets were 1/8" too small for the stock B-series hoses. I switched to a Del Sol VTEC radiator (same radiator as a 99-00 Civic Si), and it has the proper inlet/outlet size. It's also a dual-core.
Old Nov 13, 2007 | 12:32 AM
204hatch's Avatar
you need to use your old integra hoses, or some new spoon's
str8JDMteggy
Feb 14, 2007 10:07 AM
alex_s817
Aug 3, 2006 10:17 AM
hatchydude
13
Jun 15, 2006 12:18 PM
NoLeftTurn
Dec 8, 2005 05:47 AM
89Si
Jul 9, 2003 06:12 AM
