synchros for $15 each or oem kit for $350
Old Nov 11, 2007 | 07:00 PM
vtiperu's Avatar
Default synchros for $15 each or oem kit for $350
well i have a minimum 3 gear grind, cause Im doing a turbo project i dicided to rebuild my tranny wich way should i go buying oem synchros (they are called bronzes locally) or local made bronzes, quality is very good, I have Ifriend with a locally made final drive and his tranny is smooth.
Old Feb 6, 2008 | 03:16 PM
ej8's Avatar
ej8
Default Re: synchros for $15 each or oem kit for $350 (vtiperu)
gearspeed carbon coated synchros
Old Feb 6, 2008 | 05:34 PM
ejoner's Avatar
Default Re: synchros for $15 each or oem kit for $350 (ej8)
Its up to you man, if you want to trust the rebuild on non oem parts then go ahead but most people will recommend oem because theres more trust in it.
Old Feb 6, 2008 | 05:59 PM
blwn95civic's Avatar
Default Re: synchros for $15 each or oem kit for $350 (ejoner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ejoner &raquo;</TD></TR><TR><TD CLASS="quote">Its up to you man, if you want to trust the rebuild on non oem parts then go ahead but most people will recommend oem because theres more trust in it.</TD></TR></TABLE>
for sure
Nicks95GSR
Mar 27, 2008 11:19 PM
roc
Sep 8, 2007 01:05 PM
ketchup!
Feb 11, 2006 02:27 PM
Try2Live4God
Sep 22, 2004 05:05 AM
