Gas milage down the toilet
Old Nov 11, 2007 | 03:55 PM
lude98SH's Avatar
Default Gas milage down the toilet
Well I have no idea what happened but all of a sudden the last two weeks or so the gas milage on my 95 LX 4 door has been horrible. I used to get around 27-30 mpg highway and city. Now im only getting around 20. Cap and rotor are new, wires are new, plugs are new, oil was just changed, tire pressure is good and tires are new, tranny was just flushed. The only thing i have not done on this car is the fuel filter and ultrasonicly cleaned the injectors, which im doing soon however I cant see that being why gas milage just dropped off so bad. And also driving habits are the same, the car is slow bone stock so i drive it like that.
Old Nov 12, 2007 | 09:46 AM
D16Z6racing's Avatar
Default Re: Gas milage down the toilet (lude98SH)
Air filter?
Exhaust system leaks?
Old Nov 12, 2007 | 10:07 AM
joc1394's Avatar
Default Re: Gas milage down the toilet (D16Z6racing)
Stuck open Thermostat? I had that problem once when it got cold with my previous car... Just something quick to check and cheap to fix if you do it yourself.
Just an idea for you.
Old Nov 12, 2007 | 11:12 AM
kildar's Avatar
I would double check the vacum lines for pressure leaks or disconeted hoses. then i would doublecheck your mass airflow sensor. If any dash alert lights appear, you can go to a local Auto Zone and get a free computer readout from your ECU. Best of luck. Try a new air filter and feul filter too. Oh and if you do get cold air or other vehicle mods, remember that you have an OBD2 ECU. Ussually not friendly to modifications.
Old Nov 12, 2007 | 03:57 PM
lude98SH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D16Z6racing &raquo;</TD></TR><TR><TD CLASS="quote">Air filter?
Exhaust system leaks?</TD></TR></TABLE>
Air filter is clean. Exhaust system is in good shape.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joc1394 &raquo;</TD></TR><TR><TD CLASS="quote">Stuck open Thermostat? I had that problem once when it got cold with my previous car... Just something quick to check and cheap to fix if you do it yourself.
Just an idea for you.</TD></TR></TABLE>
Hmm that could be it the warm up times are alittle too long even with the colder temps. I prolly just change that, its a $10 part at most so theres no harm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kildar &raquo;</TD></TR><TR><TD CLASS="quote">I would double check the vacum lines for pressure leaks or disconeted hoses. then i would doublecheck your mass airflow sensor. If any dash alert lights appear, you can go to a local Auto Zone and get a free computer readout from your ECU. Best of luck. Try a new air filter and feul filter too. Oh and if you do get cold air or other vehicle mods, remember that you have an OBD2 ECU. Ussually not friendly to modifications.</TD></TR></TABLE>
They dont have MAF, it uses speed density. And a 95 is obd 1. Thanks though
GoLowDrew
Sep 8, 2012 04:54 PM
Oreo-TeCk
Sep 28, 2006 09:30 AM
josephshark
103
Feb 2, 2006 09:03 AM
ej1 pilot
Mar 23, 2004 10:38 AM
jman
Oct 29, 2002 03:56 PM
