wet and dry compression test results can I still run nitrous? What could it be?
Old Nov 11, 2007 | 02:54 PM
silverlude80's Avatar
Default wet and dry compression test results can I still run nitrous? What could it be?
Just completed the wet comp test results exactly as you said to do, here they are
Dry Wet
#1 150 175
#2 170 200
#3 185 210
#4 185 210
They all seem to be varying by around 25.
Also there is oil on the valve cover where the spark plugs install around the holes, also around the seal of the valve cover, and the distributer. The new spark plugs I installed yesterday are already black so I know the car is running really rich, I have no idea if that means anything. I have read running too rich can wach away some of the oil around the rings. On the dyno, it ran around 13's off the juice and as low as 11's on the juice. I know I'm not an expert by any means, but I really wonder about that head gasket. I replaced it when I had the 3 angle valve job done and don't remember what brand name it was. Also my buddy put it on, he did all the work for me back then because I didn't know crap. It is easily possible that he messed up the torque sequence, don't even know if he torqued them at all. He never used a manual I know that. That was a few years ago, I guess I'm lucky. I know I sound like an idiot now, but I just had no idea what I was messing with back then. I am just now catching up and learning to do my own maintenance and research. I am an electrition by trade, I worked on helicopters for the army, so I'm not an idiot, and I can learn. If I do need to replace the head gasket, how difficult is it? I will take the car to honda this week for the leakdown test. There is someone that had the exact same setup as me with more mods for the fuel system, and the exact same compression results who blew his engine on the 3rd pass w/ a 75 shot. The only difference was it was a dry kit. That got me worried as hell. He did not hit the rev limiter or anything like that. Also, how do I tighten my belts, where is the tensioner bolt? I've got the unorthodox pulley kit (I'm removing the crank pulley due to all the controversy), and Its squeeking at start up until it is warm.
Thanks again for taking the time out.
Old Nov 11, 2007 | 03:15 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: wet and dry compression test results can I still run nitrous? What could it be? (silverlude80)
That is a lot of variation on the dry test. How much oil did you add for the wet test? Have you adjusted your valves recently?
Regarding the oil in the spark plug holes, check your PCV.
Old Nov 11, 2007 | 04:32 PM
pgpbubble's Avatar
Default Re: wet and dry compression test results can I still run nitrous? What could it be? (Dogginator)
I personally wouldn't.
Theres more of a variance between dry then there is wet. Which is telling you its something else other then the rings.
Old Nov 11, 2007 | 07:14 PM
Added a cap of oil in each. Have not had the valves adjusted since the head was put back on and had the valve job done years ago. Will have honda do an adjustment when they do the leak down test, thanks for the reply. I don't want to throw the bigger shot on until I get this figured out. Hopefully honda can shed more light on this.
HDX15
11
May 14, 2013 04:30 AM
silverlude80
Nov 11, 2007 02:52 PM
Haccordclub
May 21, 2007 08:08 AM
95dc2teg
May 11, 2007 11:15 AM
Aeka GSR
Oct 4, 2002 11:44 PM
