Help!!!!! BDL throttle body problem
Old Nov 11, 2007 | 02:28 PM
Bakersfieldgsr's Avatar
Default Help!!!!! BDL throttle body problem
well i just baught a new bdl 70mm throttle body . and slaped it on to my blox intake manifold but . when i start the car its starts poping like crazy. so i tryed messing with the tps and its still poping like crazy and at times. the idel will be 1000 then get stuck at 2500 so if anyone has had this problem or knows how to tune it in or can give me some instructions . please help. thanks honda-tech.
Old Nov 11, 2007 | 06:05 PM
non-VTEC's Avatar
Default Re: Help!!!!! BDL throttle body problem (Bakersfieldgsr)
sounds like maybe you have a vacuum leak. check that you have the correct gasket and its not damaged.
Old Nov 12, 2007 | 03:34 PM
arc_55's Avatar
You should reveiw your tune after installing that throttle body. Also i am not familiar with those throttle bodies, but i am assuming they have a throttle stop and idle screw adjustment atleast. Also are you running an IACV?
b18b1ef8
Aug 7, 2008 10:03 AM
Des9255
Oct 24, 2005 09:58 PM
mkinpwrat12g's
Sep 1, 2005 07:12 AM
poop32145432
Mar 28, 2004 10:01 PM
ultra efro
Feb 22, 2004 05:53 AM
