Changing ATF
Old Nov 11, 2007 | 02:23 PM
betta285's Avatar
Default Changing ATF
could anyone give me a quick walk through of changing the ATF? 97 accord lx , 4cyl.
Old Nov 11, 2007 | 02:33 PM
Tech-Nics's Avatar
for starters...only use "Honda ATF Z-1" tranny fluid.
make sure the engine is slightly warm and not cold. the drain plug is located behind the passenger side wheel. you can use a socket wrench to remove it, i dont recall what size but its pretty standard size. make sure you let the fluid drain out till there is slight trickles of it, you wont be able to get all the tranny fluid out cause this is not a flush, but you get most of it out, once you are ready to put in the fresh new "Honda ATF" all you need is about 3 to 4 MAX bottles Honda ATF, once you have put in the first full bottle, turn on the car and keep gear in neutral and continue to add the other bottles in once all in put back the dip-stic, then put your gears through a cycle for about a minuet. go from R to D to N to D3 to D2...etc then what i do just to make me feel better, i go for a 5 minuet drive around to let the fluid heat up nice...hehe
its like changing the oil minus the oil filter...
its recommended by many to do this drain & fill once a year, some even do it when the season gets cold & warm..(for those who live in those climates).
Good Luck and always take care of that Honda PLEASE...
CRP
Nov 5, 2017 01:06 PM
quiet4no1
Apr 2, 2009 10:59 AM
SpazMan
Apr 29, 2008 09:41 AM
globy123
Dec 17, 2006 07:20 PM
DeDonDeRosa
Jul 30, 2002 01:08 PM
