FS: 1994 SOHC VTEC D16Z Swap
It was removed from my 1994 Civic EX with 183,xxx miles. Motor was running fine before it was removed. Leakdown was performed on all four cylinders. Cylinder 1 was 5%, cylinder 3 was 6%, cylinder 4 was 6% and cylinder 2 was 10%. Passed smog easily right before it was swapped out. Comes with everything seen in the pictures including the rear tranny L bracket, axles and original untouched P28 ECU. Complete changeover minus shift linkage. GONE!! To FLATBUSH PROJECTS
Modified by HRC51 at 12:21 AM 11/18/2007
Modified by HRC51 at 1:13 AM 12/3/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedNOTHARDLY »</TD></TR><TR><TD CLASS="quote">if you want to part out, </TD></TR></TABLE>
i'd like the ECU
i'd like the ECU
