obd0 to obd2 ??
Old Nov 11, 2007 | 11:28 AM
URN2D's Avatar
Default obd0 to obd2 ??
what exactly do i need to do in order to put an integra odb2 b-18 into a honda ef 90 si??
Old Nov 11, 2007 | 12:31 PM
Blown90hatcH's Avatar
Default Re: obd0 to obd2 ?? (URN2D)
Completely depends on what ecu you want to run and if you need it to pass SMOG/Emissions stuff.
If you want to run the OBD2a or OBD2b ecu, then you will need to get an Pre-OBD to OBD2a or b conversion harness (www.rywire.com) and then you can use the OBD2 distributor and O2 sensors.
Did you get the entire swap? Distributor, injectors, both secondary and primary O2 sensor, ecu, engine harness, etc? Need more information on the swap.
You can also get a pre-OBD to OBD1 conversion harness and run an OBD1 ecu with only one 4 wire O2 sensor and still be able to use your OBD2 distributor, etc. Many options, just need to know what you want to do.
Old Nov 12, 2007 | 07:20 AM
URN2D's Avatar
I have the complete swap with everything including the wiring harness. My friends say i half to convert the car to obd1 to run the obd2 engine..
Randysi
10
Jul 23, 2012 09:07 AM
hatch96y7
Jun 19, 2007 03:26 PM
trust01
Mar 2, 2006 04:18 PM
jaydm ferio
Oct 20, 2004 04:14 PM
Quick 200k Mile Motor
13
Jul 25, 2002 09:11 AM
