new suspension set up with PROBLEMS
I bought some springs and struts. I got the skunk2 springs and the kyb br-2 struts but it sits to low...I was wondering if any one else has these springs on there car and how low it sits..
my oil pan is only 4 fingers off the ground
ya dont worry about it man, my EF is lower then that and i never had any problems with my car being so low. Also i drive on some pretty bad roads. Just leave it looks real Nice!!!
well how much clearance does your oil pan have...im running b-series in mine...also I put the springs on the smaller ones.(right ones in 2nd pic) now I have 2 finger clearance between the fender and the tire
also can any one post pics right now because its not letting me?
Hahaha thats I always thought my Rex sat low. Then I got a miata, I had problems putting it on the lift stock. We had to push it on, since then I got it lowered approximately 50 mm. LOL I love my car and everyspeed bump regardless of size is always a huge problem.
From: Where the wild things are in, NY, United States of America
gotta remember, 98% of springs designed for our cars aren't meant for b's. Progress makes nice b-swap springs, but other then that they are horribly undersprung for swapped cars, and i believe the sk2s are no different. the wider in diameter spring is going to be the correct spring for the front. I'd just sell them and get something that you know will have a reasonable ride height (tanabe makes a nice spring for the B-powered EFs as well)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ComeOnKip »</TD></TR><TR><TD CLASS="quote">gotta remember, 98% of springs designed for our cars aren't meant for b's. Progress makes nice b-swap springs</TD></TR></TABLE>
I have the Progress coilovers and there's only a finger gap between my fender and tire. Never had a problem rubbing at all or anything like that. I wouldn't trade my suspension setup for anything.
Should've just gotten some ground controls. Those GR-2's are not gonna last long with higher rate springs. GR-2's are intended as OEM replacements not as a high performance replacement...need either gas-a-justs or AGX's. I'm not a big fan of KYB's anyways I'm partial to Koni.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RockinthEFhatch »</TD></TR><TR><TD CLASS="quote">
I have the Progress coilovers and there's only a finger gap between my fender and tire. Never had a problem rubbing at all or anything like that. I wouldn't trade my suspension setup for anything.</TD></TR></TABLE>
Which type do you have? I got the Progress Type II's on my sedan... LOVE them, its pretty much a Carrera shock with a coilover kit on it and the mounting brackets attached to the bottom, but its a hell of a set up. I also wouldn't trade mine for much ( maybe some penskes
)</TD></TR></TABLE>
I have the same, Competition 2's. Phenomenal. But I also have a Carrera...
The Carrera's braking system makes it feel like it handles better, but I'd bet my CRX holds more cornering G's. Regardless both are the ******* MAN when it comes to handling.
EDIT: By "I" I mean my father. And by "Carrera" I mean Carerra S
)</TD></TR></TABLE>I have the same, Competition 2's. Phenomenal. But I also have a Carrera...
The Carrera's braking system makes it feel like it handles better, but I'd bet my CRX holds more cornering G's. Regardless both are the ******* MAN when it comes to handling.EDIT: By "I" I mean my father. And by "Carrera" I mean Carerra S
EDIT: By "I" I mean my father. And by "Carrera" I mean Carerra S</TD></TR></TABLE>
LOL, wow. Carrera can mean a bunch of things apparently. I was refering to Carrera Shocks / Dampers, part of the QA-1 corporate family. If you look at how the shock is made (and you're a parts nerd like me), I believe theres only two companies in the country that can "crimp" a shock closed like that, the two being Carrera and Monroe. So I'm thinking progress just gets their valving specs and sends it off to carrera to have the shocks made, they might make the bodies an just have carrera crimp it as well, I'm not sure. Either way, they are quality pieces and my sedan handles like a banshee now.
The Carrera's braking system makes it feel like it handles better, but I'd bet my CRX holds more cornering G's. Regardless both are the ******* MAN when it comes to handling.EDIT: By "I" I mean my father. And by "Carrera" I mean Carerra S</TD></TR></TABLE>
kloscivicsi
Honda Civic (2006 - 2015)
Sep 24, 2007 06:55 AM
