TRU-BOOST Gauge-Type Controller
Old Nov 11, 2007 | 08:58 AM
Laserjock's Avatar
Default TRU-BOOST Gauge-Type Controller
$280 shipped in the mainland US
Brand New in box. It was never installed.
HT reviews here:
https://honda-tech.com/zero...age=1
__________________________________________________ ___________
http://www.aempower.com/ViewCa...ID=68
AEM’s TRU-BOOST Gauge-Type Controller is an electronic boost controller that combines the simplicity of a manual boost controller with the added ease of adjusting boost levels through a gauge interface. There is no external interface required for set up, and it is fully functional right out of the box. There are no gimmicks or special software programs included. If you want more boost press the button on the right of the gauge face, and if you want less boost press the button on the left of the gauge face. It’s that simple, and IT WORKS!
AEM’s TRU-BOOST Gauge-Type Controller includes everything you need, including an on-board 29 psig pressure sensor, built-in Overboost protection with two timed shutdown levels, a scramble boost setting and a low-side output for a warning light. AEM offers a 75 psia boost sensor for high boost applications (sold separately).
AEM’s boost control solenoid (included) is the only one specifically manufactured for automotive boost applications, which means it won’t corrode and stick from exposure to rich fuel mixtures, it is pressure tested to 100 psi and includes -4 AN fittings to eliminate any chance of leaks.
No external interface required for programming!
Complete system includes harness, boost hose, on-board 29 psig pressure sensor (external 75 psia optional), boost solenoid, gauge display and all necessary fittings
Quick connect technology eases the installation process
Two user selectable boost settings with peak boost memory
Scramble boost setting allows user to momentarily change boost levels
User selectable Overboost alarm includes two timed shutdown levels at 10% and 20% Overboost
User configurable gauge includes 24 scalable LEDs, and interchangeable bezel, pin guide and faceplate to customize look of display
One (1) low-side output included for warning lights
Click My Profile For Honda - tech Vouch list
Paypal verified. I'll eat the fees
Modified by Laserjock at 1:30 PM 11/11/2007
Old Nov 11, 2007 | 09:11 AM
moomakudafi's Avatar
Default Re: TRU-BOOST Gauge-Type Controller (Laserjock)
bump for you! nice piece
Old Nov 12, 2007 | 10:42 AM
Laserjock's Avatar
Default Re: TRU-BOOST Gauge-Type Controller (moomakudafi)
thanks
Old Nov 17, 2007 | 03:14 PM
Laserjock's Avatar
bump boosters
Old Nov 21, 2007 | 05:33 PM
Laserjock's Avatar
heya!
mrm1ke02
Jan 22, 2008 08:22 AM
Mike@CCT
Aug 23, 2007 11:55 PM
olddohc
Jul 30, 2007 12:49 AM
InjectedPerformance
Aug 22, 2006 01:18 PM
yellow munson
May 28, 2005 06:51 PM
