HELP. GSR swapped EG axles. HELP
Pics at bottom of page
Alright so i drive pizzas for a living and my axles started knocking in my 94+ gsr swap eg civic hatchback . i bought b-series axles cause every where i looked said thats what i needed. I put the new ones next to the old bad ones and they definitely are not the same size. do i have to buy hybrid ones from hasport or raxles or is there a cheaper way. I work at 11 tomorrow so obviously i;m going to have to call in or borrow a car.
any suggestions
Modified by anotherwhitehatch at 11:03 PM 11/11/2007
any suggestions
you need 94+ integra axles any model EXCEPT Type R (i'm also assuming you will need NON-ABS axles)...you can also use axles from a 94-97 Del Sol VTEC or a 99-00 Civic SI
sounds like they gave you the wrong axles.
you pretty much just told me that i need b-series axles.
They aren't matching up. i;ll take pics of the old and new ones
Modified by anotherwhitehatch at 12:32 AM 11/11/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by forcefedferio »</TD></TR><TR><TD CLASS="quote">you need 94+ integra axles any model EXCEPT Type R (i'm also assuming you will need NON-ABS axles)...you can also use axles from a 94-97 Del Sol VTEC or a 99-00 Civic SI
sounds like they gave you the wrong axles.</TD></TR></TABLE>
type r axles are the same as any other 94+ integra axles
axles from the following car will work
-93-97 honda delsol vtec
-99-00 honda civic si
-94-01 acura integra
If it's definitely an axle problem, hasport should fix it:
http://hasport.com/products/axles.htm
"92-00 Civic, 94-01 Integra, 93-97 Del Sol
Part#: EGBAX
2 Custom axle shafts for use with the B-Series engine swap with a hydro transmission completely assembled with CV joints and boots."
Part#: EGBAX
if you gave teh counter guy the make and model of your car he prob just gave you D series axles.
go back and tell them you own a 94 integra with vtec and your recieve the correct axles.
ok i got the same car with a gsr... ask for integra axles with no abs.... and they will fit perfect oohh yea ask for the gsr axles not just anyother b series cuz theres more then one type of b series .... but they will give u the right ones if u ask wat i just told u!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n1_egsex »</TD></TR><TR><TD CLASS="quote">
-94-01 acura integra</TD></TR></TABLE>
bullshit....ITR axles are bigger where the shaft goes into the hub and will not fit without ITR hubs.
93-97 del sol VTEC????? i said 94-97 del sol VTEC because in 1993 there was NO del sol VTEC.
future reference, don't correct my information with your misinformation.
kthxbye
kthxbye
these are the old and new axles.
The bottom new ones are gsp new cv halfshafts item #NCV21525 for any b-series motor but for my sake b18c1, specific models are listed many times above.
The top one is the old torn boot axle from passenger side. the inner joint appears identical but the outer joint is something funky, at least to me.
[IMG]
[/IMG]
[IMG]
[/IMG]
Can anyone tell me what i got and what i need
Could i have a different transmission
Modified by anotherwhitehatch at 11:35 PM 11/11/2007
[IMG]
[/IMG][IMG]
[/IMG]Can anyone tell me what i got and what i need
handa
Jun 14, 2005 09:00 PM
DRKSol
Dec 14, 2003 10:04 AM
