does your oem lsd make noise when turning?
i can hear this sound when i am making slow turns during manuvering, kinda sounds like "woog woog". any other guys experience this with your oem lsd?
JDM LSD, and it doesnt make any noise, turning or at any speed. Change the oil asap, to see what going on, before it takes the tranny out to.
If no metal shaving or anything, maybe its on its last leg(just a guess BTW). Whats the mileage?
the thing is i just had it overhauled, i installed a 4.9 fd along with mf 3,4,5th gears and carbon synchros. i heard the sound after that, dunno if the sound is due to the fd, though i doubt it. aside from the noise everything works perfect. the noise isn't that loud, but it's definitely present
Mine made noise under the conditions you mention, several years ago after the first (and last) tranny fluid change done at the dealer. I took it to my friend's shop and did another drain & fill. The old fluid looked fine. No noises after that. I think they may not have filled it enough. Never found out for sure.
hmm that's a good point, i wasn't there when they filled up the tranny. i'll try to drain and refill
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by an2ny888 »</TD></TR><TR><TD CLASS="quote">hmm that's a good point, i wasn't there when they filled up the tranny. i'll try to drain and refill </TD></TR></TABLE>
With my first itr, the dealership replaced the tranny fluid with some non-Honda fluid, it made noises at slow speed. I brought the car back and they changed the fluid out for the Honda fluid, the noise was gone and I never heard it again.
I've blown up a tranny or something, but never had any other noises except for totally fk'ed bearings.
Are you sure it's not a axle problem?
Good luck.
Good luck.
