dx master cylinder same as ex master cylinder? no abs
well my master cylinder is fucked up on my 94 ex coupe non abs , my freind gave me one from a 93 civic dx , they look the same but the booster is smaller on the dx , will boster fit on my fire wall from dx? and does it really matter can i just swap the dx master cylinder/bosster on to my car , im really just trying to swap master cylinders , please let me know wat u think
Dont quote me but if the hard line input spots into the Master are the same and both Non Abs it should work.. Another tip i would do is bench bleed the new one soo little air in the system when you put it in which= Less bleeding.
The ex has a larger mc then the dx .
part number for ex
46100-sr3-913
part number for dx
46100-sr3-003
will it bolt up and work yes does it move enough volume of fluid for the larger brake system on your ex no. When it comes to the brake system just buy a reman unit there is no reason not to.
part number for ex
46100-sr3-913
part number for dx
46100-sr3-003
SolAssassin
12
Feb 20, 2008 04:36 PM
andreysibiris
Mar 24, 2006 09:17 AM
