Rear Brake Line
I am trying to buy new soft brake lines to do my rear disc swap with but in this diagram i cant figure out which number is for the brake line itself....I need the line that connects from the hard line to the caliper.
UPDATE....I FOUND IT...THE PIC WAS MUCH EASIER TO SEE ONCE I POSTED IT HERE...WAS VERY BLURRY ON THEIR WEBSITE...THANKS....#28
Modified by LSej1 at 2:05 PM 11/10/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSej1 »</TD></TR><TR><TD CLASS="quote">I am trying to buy new soft brake lines to do my rear disc swap with but in this diagram i cant figure out which number is for the brake line itself....I need the line that connects from the hard line to the caliper.
you need item #3 & #4. the lines and the the hardware that comes with it.
Modified by philosofy1 at 2:07 PM 11/10/2007
</TD></TR></TABLE>you need item #3 & #4. the lines and the the hardware that comes with it.
its about 45-50 for the set...not too bad...if its the line im thinking of i dont know how i am going to get it on the car...arent the stock ones welded on to those brackets?
EF_ST@TUS
Apr 12, 2006 01:00 PM
