spark plugs / wires?
Old Nov 10, 2007 | 09:05 AM
northworm's Avatar
New User
Default spark plugs / wires?
I'm looking to tune up my recently purchased 98 accord EX 4 cylinder. Which plugs and wires should I use?
Old Nov 10, 2007 | 09:56 AM
Chiovnidca's Avatar
Default Re: spark plugs / wires? (northworm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by northworm &raquo;</TD></TR><TR><TD CLASS="quote">I'm looking to tune up my recently purchased 98 accord EX 4 cylinder. Which plugs and wires should I use?</TD></TR></TABLE>
If it still has the original plug wires on it i'd keep them unless they show signs of damage. Stock wires are very durable.
Old Nov 10, 2007 | 10:06 AM
fatboy1185's Avatar
Big Cat
Default Re: spark plugs / wires? (Chiovnidca)
NGK is always decent choice
Old Nov 11, 2007 | 07:01 AM
northworm's Avatar
New User
Thanks for the replys. My accord has 140,000 miles on it and since it's new to me, I'm not sure if its the original wire set. They say 'prestolite' on them. Are these original, and if so, is 140,000 miles about time to swap them out? I know NGK makes a set, should I go with them or something from the Honda dealership?
Old Nov 11, 2007 | 07:51 AM
GhostAccord's Avatar
Default Re: (northworm)
In my manual it states that NGK's are the OEM wires for My 96. If you go to the dealership that's probably what you'll get. Prestolite are a replacement wire. Therefore your wires have probably been replaced. If you have a multimeter or Ohm meter handy you can give your wires a check. The resistance of every single wire shouldn't exceed 25 kOhms. If they exceed that you should replace them.
Old Nov 11, 2007 | 08:47 AM
kjmoy's Avatar
I would only use genuine Honda spark plug wires, distributor cap and rotors. I would buy platimum plugs from autozone or pebboy. personal choice. I had problems with my previous Hondas using non-Honda plug wires (79 88 Accord). Currently my wife drives a 96 Accord (6cyls EX).
firaga21
Oct 29, 2008 05:36 PM
honda94accord
Apr 10, 2007 07:27 PM
ZXRider
Sep 11, 2006 10:05 PM
Jaydeep
14
Aug 17, 2004 10:24 PM
SilverIntegra
Apr 2, 2002 08:32 AM
