Help with my CRX?! (oil pressure problems)
Start with the car: 1991 CRX Si Converted to OBD1
Engine: A6 Block / Y7 Head. (oil pan is from a z6)
Sensors/dizzy etc are all obd1.
As you can see it's kinda a mix of parts that I had lying around from other swaps/cars etc....
I am not getting any oil into the head. I have done "Mini-Me's" on CRX's before and always removed the oil jet. (this car is NON-Vtec! you read right it's a y7)
Does anyone know (without any doubt) if I need to remove the oil jet on this setup? I need to know if it's the oil pump or something simpler.
Any other a6 block y7 head specific problems that I might want to know about?
I am getting rather frusterated becuase:
#1- I can't get the dash to work! (problem from the previous owner) to check if the oil light is on!
#2- the oil does not seem to be getting to the head! ARgh!!!
TIA ~Brett
TIA ~Brett
