Buying S2000 But Rear End Vibrates under Acceleration
Need help, i'm in process of buying an S2000 but when the car is over 4000rpm the rear end of the car starts vibrating and kind of wants to pull to the passenger side. under 4000rpm's it drives normal the tranny shifts perfect, only when under heavy acceleration it vibrates. ANY Suggestions.
yeah don't buy it....you're not obligated to, so go find an other one. easier to find one that doesn't need work then get yourself into something that may be more than you want to handle
It sounds like a extremely simple fix and also a very common problem with most s2000's. The cv cups need swapped from right to left. I can send you a DIY if you like. I will be doing it to my S this week.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RUEHL925 »</TD></TR><TR><TD CLASS="quote">It sounds like a extremely simple fix and also a very common problem with most s2000's. The cv cups need swapped from right to left. I can send you a DIY if you like. I will be doing it to my S this week.</TD></TR></TABLE>
hey how bad does ur car shake an dswapping the cv cups did it take care of the problem. ok i'm about to buy this car but i'm worried if the Diff is going bad i only feel the vibration when i punch the gas all the way in. thanxs
I agree also. It may be the cv boots. I had the same problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote"> cv boots </TD></TR></TABLE>
Not the boots...the boots are just rubber.
It is the CV buckets that need to be swapped left to right or replaced.
And if you do this, you do not need spring spacers even if the car is lowered.
