shift bushing install..tranny fluid?
Old Nov 9, 2007 | 03:21 PM
InMyProject's Avatar
Default shift bushing install..tranny fluid?
friend of mine has an eg hatch with gsr swap.. he was changing the tranny side shift bushing.. is tranny fluid supposed to come out? ;x
Old Nov 9, 2007 | 04:54 PM
davidv433's Avatar
that happened to me b4, the bolt that goes in there is short, he might have used a longer bolt and punched thru the trans, i did that b4 and i couldnt stop the leak.
Old Nov 10, 2007 | 08:03 AM
hm, he used the bolt that came out of it..
anyone else know if that bolt hole is connected to the trans resevoir?
Old Nov 10, 2007 | 08:09 AM
BryanM.'s Avatar
Resident Gearhead
Default Re: (InMyProject)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InMyProject &raquo;</TD></TR><TR><TD CLASS="quote">anyone else know if that bolt hole is connected to the trans resevoir?</TD></TR></TABLE>
Definetly not. Hopefully he didn't over tighten the bolt and crack the trans.
Old Nov 10, 2007 | 10:21 AM
g3integragsr's Avatar
* B A N N E D *
there should not be any fluid associated with that bolt what so ever unless he over tightened and cracked the trans casing. Have him check the axle seal right above that to see if there is fluid around that. If so its the axle seal thats bad.
Old Nov 10, 2007 | 12:41 PM
weird... when he took the bolt out to change the bushing.. thats when it started pouring out of the bolt hole.
Old Nov 11, 2007 | 10:13 AM
* B A N N E D *
If thats the case then the someone put the wrong bolt in there. A bolt being to long would have punctured through the side of the casing....therefore making a hole to leak from
bad 91 teg
Feb 1, 2011 04:09 PM
G2_Fella
Oct 10, 2008 04:43 PM
91redteg
Aug 7, 2007 09:27 PM
89DXDann
May 24, 2004 12:47 AM
RCautoworks
Feb 16, 2003 11:16 PM
