buying a ... UPKEEP?
i am buying my first RSX and i def wnated the type s .... the engine has 84K on it... what are the things i should change before heavy driving (specific to this car) not in general... IF ANYTHING ... or watch out for... ENGINE unmolested...
2002 dc5
thanks
2002 dc5
thanks
While you are considering your purchase and sitting in the car, read that wonderful owner's manual that is provided with each new vehicle (the seller does have the owner's manual, don't they?) and compare it with the service records the owner has (they should have a record of services performed). If the history shows deficiencies in the maintenance of the vehicle, those are the areas of upkeep you may want to adress. Driving, heavy or otherwise, does not alter the basic service intervals or requirements.
As for what to watch out for... that vintage has had problems with a stiff shift or grind into second gear. Annoying rattles were a popular complaint too.
If you haven't already, check out http://www.clubrsx.com and search for your questions. A recent thread discusses the pros and cons of buying an '02 vs an '05 and may be of interrest to you. Here's the link.. http://forums.clubrsx.com/showthread.php?t=524785
lsturbo*
14
Nov 2, 2012 05:08 PM
pcorad
Jan 18, 2002 11:12 AM
RATEDR
Aug 6, 2001 11:41 AM
