no compression 95 accord.
Old Nov 9, 2007 | 12:43 PM
raymondlee's Avatar
Default no compression 95 accord.
I have a 95 accord that was cranking fine until i took the head to replace head gasket. put everything back no it doesn't crank and it sound just like the clip on youtube
http://www.youtube.com/watch?v=HWnMxJp97-o
<object width="425" height="355"><param name="movie" value="http://www.youtube.com/v/HWnMxJp97-o&rel=1"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/HWnMxJp97-o&rel=1" type="application/x-shockwave-flash" wmode="transparent" width="425" height="355"></embed></object>
the car just turns over and thats all. was its something i missed during reassembly
95 accord lx
186,xxx miles
if the video does work just go to youtube and search for " no compression". any help would be appreciated
Old Nov 9, 2007 | 04:50 PM
accord99power's Avatar
Default Re: no compression 95 accord. (raymondlee)
did you compression check, or fuel/spark test? prolly forgot to hook something up, but how do you know no compression?
Old Nov 10, 2007 | 05:40 AM
raymondlee's Avatar
gettin fuel, how can i check spark?
if its no spark what would cause that?
no i didnt do a compression test i just called it that because that was the video's title and my car sounds exactly the same.
if my timing is off would it cause it to do that?
what do i need to check?
thanx
Old Nov 10, 2007 | 05:44 AM
dtapia's Avatar
Default Re: (raymondlee)
yes is the timing belt is off it can do that.was is on tdc when you took it apart and when you put it back together ? i would start at the basics first.
did you take the t/stat off ?
Old Nov 10, 2007 | 05:48 AM
Duane_in_Japan's Avatar
Default Re: (dtapia)
Valves may be adjusted too tight and not allowing a good seal to build up compression.
Old Nov 10, 2007 | 05:54 AM
hondaccord's Avatar
t-belt could cause it, it might be 180 out. you should go get a compression gauge there like 20 bucks over at autozone. that way you can tell if its across all cylenders, or one or two.
Old Nov 10, 2007 | 09:16 AM
raymondlee's Avatar
ok. distibutor was unplugged. car started but it runs like crap. if i dont give it gas it will cut off.
what now? and sorry for my noobness
Old Nov 10, 2007 | 05:45 PM
CD5 Jeebies!'s Avatar
From: Free bullets if you find me sucka, Washington
check your timing
Old Nov 11, 2007 | 01:59 PM
hondaccord's Avatar
Default Re: (I got the CD5 Jeebies!)
if not the timing check for air leak.
dxco1
Jul 14, 2016 12:57 PM
accord96lx
Jan 6, 2012 11:13 AM
G. Man
Classic Hondas
Apr 17, 2011 06:30 PM
fastfu
Dec 1, 2005 09:49 PM
cathsgsr
Jun 25, 2003 07:58 AM
