Map sensor on the firewall..
the map sensor is on the firewall and there are two vacume lines..i know the lower one connects to the throttle body..how about the upper horizontal one ? where did that one go ? thanks
Still dealin with that eh. Actually the second one gets looped back in with the other one. Check out the pic at ff-squads technet and you should see how it comes together, you may need a t-fitting from the hardware store to make it happen.
wel no photos. but mine went to the carb can? i think that's what it is called
wel that black can under the batt. side..
well my two cents.
well my two cents.
thats on a usdm motor if the map sensor is on firewall it should be jdm but yes if it is usdm it should go back to the can but the guy said it was sir2 which is jdm
Modified by sc95delsol at 10:33 PM 11/9/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sc95delsol »</TD></TR><TR><TD CLASS="quote">thats on a usdm motor if the map sensor is on firewall it should be jdm but yes if it is usdm it should go back to the can but the guy said it was sir2 which is jdm</TD></TR></TABLE>
oh yeah well let hope to find a picture.
Brian Hinson
13
Jun 24, 2006 04:05 PM
leprechan117
Mar 30, 2003 01:06 PM
