Suspension & Brakes Theory, alignment, spring rates....
EF Rear camber link bolt... Is the nut accessible?
Old Nov 9, 2007 | 06:30 AM
import2nr88's Avatar
Default EF Rear camber link bolt... Is the nut accessible?
While removing my upper rear camber link on my crx (by hand none the less) I believe the nut on one of the two bolts holding the chassis side of the mount to the body broke loose from the chassis. Is there a way to access this with out cutting a hole into the boxed section of "frame" from the inside of the car or is that the only way?
Thanks in Advance,
Jon
Old Nov 9, 2007 | 02:56 PM
Targa250R's Avatar
be professional
Default Re: EF Rear camber link bolt... Is the nut accessible? (import2nr88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by import2nr88 &raquo;</TD></TR><TR><TD CLASS="quote">Is there a way to access this with out cutting a hole into the boxed section of "frame" from the inside of the car or is that the only way?</TD></TR></TABLE>
Unfortunately, that's the only way.
Old Nov 12, 2007 | 10:35 AM
Default Re: EF Rear camber link bolt... Is the nut accessible? (Targa250R)
Yeah thanks... Thats something that I found out after drilling a small inspection hole.
I have since cut about a 3" x 4" hole and rewelded the nut in there. Now I just have to weld it back up and make it llok decent again being that I have a gutted car there's nothing to cover it with.
Bango_Vang01
Suspension & Brakes
Feb 16, 2018 06:06 PM
stormdrop
Aug 24, 2012 06:05 AM
L8APX
13
Oct 7, 2008 08:32 AM
YAH YAH
Suspension & Brakes
May 10, 2007 05:16 PM
huge230
Nov 26, 2006 09:47 AM
